Question about Mitsubishi WS-65809 65" Rear Projection Television
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
Yes my tv is a mitsubishi big screen made in 2001 modle ws65809 i have slight goshting i tried to ajust with remote but will not any more i talked to friends that have same tv they said i need the guns ajusted
  • cztop Aug 27, 2008
    thanks i tried your solution but it stayed the same .I also tried the advanced convergence with the remote and the lines on the outer edge of screen will not line up
  • Anonymous Mar 28, 2014
    how o ajusted
    Master:
  • 505 Answers
Try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Posted on Aug 23, 2008
  • make sure its unplugged from power point
I have a Mitsubishi WS-55809 projection TV. The convergence will not ajust using the user controls and the picture looks bowl shaped in every format.
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Feb 07, 2013 | Panasonic PT-56WXF95 56" Rear Projection...
Yes i have a mitsubishi big screen tv model ws65809 made in 2001 the guns need to be ajusted can you tell me how to ajust them
dear,
what kind of problem u r facing so that u thought the guns adjustments
regards,
dont rate it untill satisfied or solved
Aug 23, 2008 | Televison & Video
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
II HAVE A 65" MITSUBISHI TV MODLE WD-62530 JUST
move all other electronics away from the screen mine did it too
Nov 17, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
How do i clean the color guns and ajusts them
sorry, you cannot perform that task. If the screen looks as if a child has been colouring it in, then you need to call out an enginner and tell him that it needs de-gausing. This removes the magnetic field and gives you the true colours back.
Oct 25, 2009 | Mitsubishi VS-7087 TV
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The picture on my Mitsubishi rear projection big screen has pink and green lines going around all of the images
you will need to ajust the convergence of your tv. there should be a "test" swich/feature that brings up a grid on the screen. ajust the horizontal and vertical of each of the colors until the lines become white. you will need to be more specific on which model you have if you need more detailed instructions. it should cost less than $75 to get a tecnician to come over to fix this.
Aug 08, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ws65809 tv
Good Day, TRAVLINMAN80;
Sorry for the late response but have been dealing with IKE down here in TX. I think the problem your TV is Fluid. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSIBUSHI WS65809 TV
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Mitsubishi WS-65809 65" Rear Projection Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
