Question about Shure Unisphere 565 Microphone
I unplugged the jack
The male end of the mike came off when i unplugged it and i dont know wich wire goes where??
  • 122 Answers
Try the scematic on your user manual.these mics have dual impendance selector and use different cable for each use.find your solution and look at the manual.if you have not the manual try to download it from the shure official site!
Posted on Jun 04, 2010
  • 56 Answers
Posted on Sep 17, 2008
How do I put back the spare tire on my 2004 Cevy siverado?
You should have jack along rod wich should have an opening on end wich will be used on your rear bumper should be a hole or opening where u will slide this rod into it while trying to turn it either clockwise or counter until this plate connected to a wire starts dropping it's where spare goes ,look in truck manual
Nov 02, 2013 | Cars & Trucks
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Sep 10, 2011 | Samsung Q430 Laptop
Bought an hdmi to dvi cable. Now I have no sound. I'm not. Sure what audio cable I need. I have an idea of what it should look like but no one has anything close to it.
The audio cable will depend on the source and the TV. If you are using a computer as the source, you probably need a 3.5 mm male/male end stereo audio cable (like for computer speakers that aren't directly wired). Plug this in to the computer's speaker (out) jack and the TV's audio in (not the headphone jack on the TV). The other possible cable would be an RCA audio cable with two colored jacks on each end of the cable. For a computer to a TV that doesn't have a 3.5 male audio in jack, you may need an audio cable with the 3.5 mm jack on one end and the pair of RCA jacks on the other.
I hope this helps.
Apr 17, 2010 | Vizio P42HD Television
Westinghouse model LCM 17V2SL what type of wire is needed to get speakers to work?
You need stereo mini phone plug male-to-male, one end goes into audio line out (green) on the PC sound card, the other end goes into audio line in on the monitor jack (green). then you need to set the volume control PC and at the monitor. You can get the cable from Radio Shack.
Mar 05, 2010 | Computers & Internet
Model 110 does not drain
if you don't want to replace the lid switch you can bypass it,remove the 2 head screws one on each side,you may have plastic caps to pop off one on each side,flip the head up,you will see the lid switch jack on the washer,unplug it,cut the 2 wires on the outside of the wire jack leave middle wire(the side of the wire jack that goes to the timer)wire them together with a wire nut,plug back in , put head back and your done,let me know how you do-mike
Apr 09, 2009 | Kenmore 22642 Top Load Washer
I have a kenmore 70 series washing machine and all of the sudden, it won't goes through the washing cycle til the time comes to drain and then stops????
unplug washer ,very simple,your lid switch is broke,remove 2 screws from head,flip head up,unplug the jack on the washer top,cut both outside wires and wire them together,plug back in,you have now by passed the lid switch,your done,let me know how you do,if that does not work we will tackle the water pump-mike
Mar 24, 2009 | Washing Machines
I have a cat5 wire. I put your data phone jaack RJ45 on one end. I put your male plug on the other. On the tester, on the input it goes 12345678 on the wall jack it goes87654321 . Wall jack is wired to...
You accidentally flipped the cap over backwards when you were putting the male plug on. If you are using 568B standard that starts with orange/white and ends it brown...make sure that if the orange white is on the left, then the clip on the plug is facing away from you.
Feb 03, 2009 | Computers & Internet
I have a Hoover Windtunnel 2 upright vvacum cleaner. During regular use my wife turned it on and it staarted cleaning, then all of a sudden it stopped and then started again then stopped for good. I...
It sounds to me like the power cord has a short. To test your power cord you need a multimeter. Test continuity threw the power cord, from the male plug prongs, to the wiring inside the vacuum. You should get continuity from one prong on the male plug to only one wire on the other end of the power cord. If you test one prong but get a readying on 2 wires, then it is crossed. If you dont get any continuity on one or more of the wires, you have a short. A common place for a short in the cord is the male plug, you can find a replacement male plug at a hardware store and cut off the old one. When wiring the male plug, black wire goes to the gold post, white wire goes to silver, and green wire goes to the green post.
If your carbon brushes on the motor are warn, then that could cause the motor to stop, but other parts of the vacuum should still work so I dont think it is that.
Hope this helps.
Jun 27, 2008 | Vacuums
Shure Unisphere 565 Microphone Logo
200 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
