Question about Cameras
Can I use nickel metal hudride batteries in my powershot s5 camera?
    President:
  • 423 Answers
Yes you can, and probably should. There's a new type of Ni-mh battery on the market which holds its charge longer than the older (regular) type. Ask about them at a good photo shop, if you're finding the rechargeables are not lasting. You might also try the Energizer Lithium AA batteries. They're not rechargeable, but really last a long time. Many of my customers rave about them.
Posted on Aug 23, 2008
Card lock for powershot S5IS
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 10, 2013 | Canon PowerShot S5 IS Digital Camera
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Hi, I have problems with my Canon powershot S5 IS, no matter what I do, my batteries are dead within 30 seconds. I've used a new pack of batteries to make 6 photo's. Anybody got advice?
it looks like the Camera Shortend the batteries
its a problem with the internal power unit one of the components is short and cause this problem
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Canon PowerShot S5 IS Digital Camera
I keep getting a battery flashing signal even with new batteries and it takes one pic and shuts off
Check the type batteries you are using. This camera uses either the alkaline batteries (don't use the cheaper brands, their residual power is much less) or the NiMH [Nickel-Metal Hydride] rechargeables. The NiMH batteries give you greater service and increased life in the camera. Nickel Cadmium batteries are unpredictable for use in this camera.
You may also want to check your battery contacts on the batteris themselves and also the contacts inside the camera. To clean the contacts inside the camera use a reliable contact cleaner. I use either NU-TROL or Deoxit. A quick squirt and cotton bud swirls will do the job. Make sure you wipe the terminals of the battery with it as well. Body oils can partially insulate from conduction. If you can't find a good contact cleaner, I found mine at Baynesville Electronics, 410-823-0082.
Hope this helps.
Sep 05, 2010 | Canon PowerShot A560 Digital Camera
Keeps saying it needs new batteries
Make sure you use rechargeable batteries2_bing.gif, as normal ones aren't strong enough. Rechargable Nickel Metal Hydride (NiMH) batteries are recomended for cameras2_bing.gif, as they are powerful.
Feb 19, 2010 | Canon PowerShot A560 Digital Camera
My camera just doesn't turn on.
i dropped my camera it is a samsung 8.2 and only the power light comes on
Sep 13, 2009 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
The battery can last only 30 min
get a high capacity Nickel Cadmium or nickel metal hydrite rechargable battery for best results. Don't go below 1500mah ratings. You may also turn off the LCD light to save on power, just use the built in viewfinder.
Dec 08, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
