Question about Toshiba CF30F40 30" TV
TV is dead
Lightning may have damaged television. I am hoping that there might be a fuse that can be reset. Can the television be reset?
I have the same problem and the tv is dead. A friend says that it is the internal power supply. The tV has two and one was blown and so it must be replaced
Posted on Dec 17, 2008
Tv dead during lightning
Could be minor or maybe done for but here goes. Some flat panel TVs have the main power cord with one of those small transformers built into the plug end that converts 120volt ac to DC power. Output voltage should be listed on the transformer tag. You need to find someone with a voltage tester and see if the TV plug end is showing DC voltage. If not the complete power cord needs replaced. If that checks out-- the next thing is to remove the complete TV back cover and look for fuses right near the power plugs into the TV. The fuses should blow out first from a lighting surge. The problem is how much of a surge you got. It may have damaged the power supply board in the TV which may need replaced. Hope this helps
Jul 12, 2015 | Televison & Video
Mintek DTV-260 Dead after power surge?
if its still covered by warranty? have it checked by a local pro or im not sure but I think mintek went out of business.
Jul 22, 2008 | Mintek DTV-260 26 in. LCD Television
Power surge caused by lightning strike, TV is dead, any Thoughtd/ does this damage every components?
Lightning can cause serious damage. You will surely want to get a professional diagnoses. What is damaged depends on where the surge came in at, and the intensity of the surge. If the surge came in through the power cable, most likely your power supply board has damage. But I have seen situations where the surge came in though an HDMI or coax connection and just take out the main board. But the moral of the story is to get a proper diagnoses, you could have several boards damaged.
Nov 24, 2012 | Astar LTV-2701 27 in. HD-Ready LCD...
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
How do I trouble shoot a tv struck by lightening ?
That is a tricky question, lightning can cause minor to severe damage. If the TV is completely dead, the power supply board will be the first order of things to check, if fuse is open chances are there will be damaged parts and open foil. If fuse blows, board replacement would be the next step, however the risk is will it work, lightning may take 1to 3 boards for example and the unfortuneate thing is you must sub boards until it works.
Mar 11, 2012 | Toshiba Televison & Video
Sanyo DSs31820 dead after lightning storm. Is there a master reset?
A lightning storm will destroy a TV in many cases. I have repaired very few, with this problem. I would certainly find a new TV, if this is the case for sure. Thanks for asking!
Jul 11, 2010 | Sanyo DS31820 31" TV
My 62 inch mitsubishi tv was hit by lighting
Try to find a local repair centre & ask if they can give you an estimate on the cost to repair. A lightning strike can cause either minor damage such as just an internal fuse blown or can cause severe damage which will wipe out entire circuit boards which can be a costly repair. In this case it's usually not worth repairing.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My Tv was off during rain but there was thunder (lightning)
the fuse is doing its job when the fuse blow it stop the components being damaged. but in this case it sounds like component failer
Jan 18, 2009 | GE 27GT616 27" TV
Lightning
Lightning damage could be all or nothing, It's very hard to tell without checks all around the boards. I think your best bet is to check with homeowners and see if they will pay for lightning damage and if they say take it to a tech to fix and they will pay, go that way. But If you want to DIY, then the best thing is to call PTS 18008447871 and price a Deflection module. This is more than likely the area, but still not 100% sure. But it has the HV area on it. This will still be around 200-300 and it most likely will fix the problem. Hope this helps!
Sep 24, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
