Question about Philips 25PS40S 25" TV
Philips tv sound doesn't work
Its not on mute but the sound just doesnt work. I've tried to turn it on and off but it still stays off.
  • 2 more comments
  • sokells Aug 26, 2008
    Turned it on and off, adjusted the sound on the menu but nothing is happening. Great picture but no sound
  • chitram Sep 11, 2008
    no sound what ever volume level, mute is not on.
  • rahmansahil Oct 06, 2008
    i too have the same problem , no sound is coming but its a great quality ..
  • Anonymous Nov 05, 2008
    same problem.. any fix without sending to the service center?
    Problem Solver:
  • 7 Answers
It could be the audio circuit faulty, either the IC or other parts - pls send to a service center.
Posted on Sep 27, 2008
2 Suggested Answers
  • 556 Answers
SOURCE: philips tv
it seems that there is a problem in your sound section. it seems that there is no proper supply to sound section or some capacitor might be faulty.
Posted on Oct 01, 2007
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
Magnavox 37MF231D
magnavox is the same unit as philips --- they are like dodge/chrysler--- made in the same factory--- try a company that services philips and they will be able to fix
Sep 05, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problem to turn on Philips TV
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
Oct 18, 2007 | Philips 27PT563S 27" TV
Philips 25PS40S 25" TV Logo
1,540 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
