Question about Fuji FinePix S7000 Digital Camera
My Fuji S7000 wont focus when I use a wide angle lens adapter.
I've since found out (via a Fuji forum) that the camera MUST be set to Super Forced Macro for the lens to focus ..... which it now does!
Posted on Aug 24, 2008
Fuji finepix s1500 - difficult to get it to focus at close macro. I found that I have to have the lens at its widest angle for the camera to focus on a close subject - like at 2 cm like the manual says. If...
Yes. You won't have the same macro focussing ability at all focal lengths.
But usually the important thing is that it's not how close the camera can focus, but how large the image is, so you'll often find that a longer focal length (i.e. not wide angle) will produce a larger image of the object even though the camera has to further away to achieve focus. This also results in less distortion as extreme close-ups in wide angle produce extreme perspective distortion. It's why a wide angle close up of a face results in an exaggerated nose and mouth.
May 18, 2010 | Cameras
Do they make a converter for cannon len to fit fugi
Depends what you mean.
The Fuji s7000 is a fixed lens bridge camera, so you can't remove the lens and use an adapter and fit other lenses.
All that you can do is to git supplementary telephoto, wide angle and extreme close up (macro) lenses to the filter thread on the end of the lens; if you use what's called a reversing ring you can then (within reason) mount pretty much any SLR lens backwards onto the front of yours. The reversing ring screws into the filter threads of each lens and will be quoted in two sizes: these will be whatever the filter thread diameter is on each lens. By mounting a lens backwards, you effectively end up with an extreme macro lens, but it all depends upon which lens you choose. The reverse mounted lens will just be a dumb bit of glass, there will be no focus or aperture control and no communication of any information back to your s7000.
Hope that I've helped, if so please rate my answer.
Feb 18, 2010 | Fuji Cameras
Need Original Lens
Hi
I am sorry to say thatbthis is not possible. The s7000 is not an interchangeable lens SLR. Lokks like one I know but the lens is fixed.
Only chance is to get the current lens repaired.
Hope this helps
marti
Sep 18, 2009 | Fuji FinePix S20 Pro Digital Camera
Focus error
Very common Fuji lens problems. Find a good independent repair shop that may be able to fix. Fuji will charge a huge sum to replace lens.
Jul 01, 2009 | Fuji FinePix S7000 Digital Camera
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Lens for a finepix s5600
I need to know if my wide angle lens will fit other camera brands
Nov 18, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
The lens makes 'graunching' noises at start-up,+ is not focusing
Cameras can be like cars. Better to keep trading them in for the newer model before they are worthless. Yes, that is the broken gears you are hearing. It may be fixable, but probably not worth the 2 hours of labor from a professional to fix it. It could just be a grain of sand in the gearbox if you are willing to spend the time to go look.
Nov 12, 2008 | Fuji FinePix S7000 Digital Camera
Conversion lenses & filters
These screw on the front of the plastic lens adapter and adjust the focal length. On the side of the adapter lenses it will quote the ratio. My wide angle says 0.66x so just multiply the range of focal lengths by this figure and you will see that it adjusts the camera zoom accordingly - making the image wider and probably also increasing the depth of field (what is in focus). Similarly a 1.5 tele will inrease the range of focal lengths to make the lens "longer" eg higher magnification , useful for astro photography - shots of the moon and terrestrial long distance work but detracting from the depth of field, eg the range of distance over which objects are in focus will be reduced.
The wide angle will allow you to come in close and get WIDE objects fully in-frame- hence "wide angle", while the telephoto will give you better overall maginification of the image but will probably increase the MINIMUM focal length - eg you may not be able to focus on objects closer than >2m (instead of ~1).
The screw-on adapter lenses I found were cheap in a Jessops sale use a 52mm thread, while the S5500 provides a 55mm internal thread. I use an appropriate 55mm to 52mm step down ring adapter. There is slight vignetting (shading around the edge of an image) at certain combinations of zoom, but generally these are very useful accessories.
As these are adapter lenses on the front of an already powerful 10x zoom that must be optically compromised at the price of this camera, there maybe some colour fringeing around bright images. If you want a better solution you really need to get a DSLR. Overall a good solution for the price.
Sep 17, 2008 | Fuji FinePix S5500 Digital Camera
Lens will not extend
normaly S7000 have a manufacturing designing defect of lense not extending. This happens due to broken gears in the lense movement assambly. The replacement of the broken gears will fix the problem
Aug 08, 2006 | Fuji FinePix S7000 Digital Camera
Wide Angle Lenses
wide angle lens aka fish-eye lens, means only the centre of your photo is clearly focused - especially in long distance scenery shots.
Sep 13, 2005 | Kodak DC290 Zoom Digital Camera
Fuji FinePix S7000 Digital Camera Logo
91 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
