My desktop is not centered and the fonts are too big. Also my Start button and bottom toolbar have disappeared.
    Novelist:
  • 210 Answers
Sounds like your resolution has been set too low.
Firstly, i'm going to assume you have a 17" LCD monitor, and that you are running Windows XP. (what a guess!) =-]
Generally, you'd want to right-click the desktop in a blank area, select properties. This gives you the display properties. Go to the last tab across called "settings", then under "screen resolution", drag the slider up a notch and hit apply. If it looks right, leave it at that. If it's not quite right, go another notch and apply. Keep going until you have it right.
But on your 17" LCD monitor, running the DVI cable to the PC... the computer should already have detected it's maximum resolution. In this case, you can drag the slider all the way to the right and hit apply, knowing that this is the optimal resolution. Also on your Dell LCD, you should have several buttons for adjusting the screen. One of those buttons is usually a "self-adjust" or "auto detect" or "some other obvious thing" for self-adjusting the screen viewable area. It *should* do this automatically when you change resolutions, which your Dell 173FPb should do anyway. =-]
Posted on Aug 23, 2008
    Problem Solver:
  • 7 Answers
Sounds like your monitor setting are messed up. Monitors have buttons on the edge or side. Pressing one of these buttons brings up a menu. There usually is an item which will grow or shink the image. Also a menu item for centering the image. Play with these and see if they help.
Be careful with "input select". Most monitors have two inputs in the back. With the "input select" button or memory item you can switch to the other input and the screen goes blank. Just switch back with the same button.
Bigpond home page back
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in www.bigpond.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have if don't need any of them you can disable or remove them.
Here is another option to add
Right click in the bottom toolbar (Bottom of Screen) select the toolbars option then Desktop this will add >> arrows in the bottom toolbar select the arrows you will see a list with control panel which has another list of all control panel items.
Mar 03, 2014 | Computers & Internet
How do I enlarge my font?
Depends on the service you use. attaching two screen caps that should help you.
Gmail
Hotmail
Aug 21, 2013 | Computers & Internet
How do i make font larger?
WHICH or WHAT PROGRAMS FONT SIZE ???????
Right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view tab from the drop down list will be a Zoom with percentages %
and text s largest to smallest
or Right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view tab from the drop down list will be a Zoom with percentages %
and text s largest to smallest.
or if its just the of the fonts on your desktop. Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings.
Always click APPLY after making any changes
Jan 30, 2013 | HP Pavilion dv7-1132nr Notebook PC
How do I return "Add a program" to the Control Panel under Programs?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 and windows 8 once you open the mouse you will see mouse and keyboard center link mid page click on that to change your mouse right click
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Hope this helps.
Dec 29, 2012 | Dell Inspiron 530s Desktop Computer...
FONT TOO SMALL
If this for a web page
and text sizes largest to smallest.
or if its just the size of the fonts on your desktop.
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings.
Hope this helps.
Dec 01, 2012 | E-Machines eMachines Desktop PC
Fix my screen size
Also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size, larger size or custom settings
always click APPLY after making any changes.
Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add to the Toolbar File Edit View Favorites Tools and Help
On the top of the internet page you should see some tabs file edit view favorites tools and help Click on the view tab on the drop down list you should see a zoom size %
Click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
There might be a menu button on the monitor where you can adjust reduce / expand the screen sizes usually located on the underside of the monitor of course this will depend on your brand of monitor.
hope this helps.
Nov 22, 2012 | eMachines D Computers & Internet
FONT SIZE ON COMPUTER IS TOO SMALL
hope it helps
Nov 03, 2012 | E-Machines eMachines Desktop PC
In gmail my font-size type is way too big. How do I change it?
To change the font size on your gmail account kindly follow the steps below.
  • Make sure the rich-text formatting toolbar is available.
    • If you see a Rich formatting » link just above the message composition area, click it.
  • Highlight existing text to apply formatting or set it before typing.
  • Click the Font button to choose a custom font.
  • Use the Size button to pick a font size, from Small to Huge.
  • May 20, 2011 | Computers & Internet
    The toolbar disappears at the top of the page when the browser opens. It stays hidden until I close the browser.
    Click 'View' from the menu bar then select toolbars and then click on standard buttons your toolbar will be back to its normal place.
    Jun 19, 2010 | Dell Vostro 220 Desktop Computer
    My tool bar disappeared. How do I get it back so
    Hello.
    Go to Tools->Toolbars->Check the toolbar you need.
    Cheers!
    Mar 30, 2010 | Microsoft Internet Explorer 7
    Computers & Internet Logo
    412 people viewed this question
    David Payne
    David Payne
