Question about E-Machines eMachines Desktop PC
Running xp home ,phone dialing reboots harddrive
Phone ringing , reboots computer from off setting
    Novelist:
  • 210 Answers
You need to go into your BIOS, and look into the various menu's until you find something to the effect of "wake on ring". Disable it or set it to "previous state" if you can.
It's a feature, which is really quite annoying!
Posted on Aug 23, 2008
Why is there no dial tone on my phone?
most likely phone line down notify phone company
Aug 25, 2017 | Computers & Internet
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
What is cause of Buzzing dial tone
This phenomenon is the phone lines and phone instrument rectifying the RF signal from your cell phone as it communicates periodically with the cell sites. The energy is rectified (turned into voltage) by the phone lines and appears as a buzzing pulsing noise in the home phone. This will trash a fax completely. There is NO solution except to turn off the cell phone or orient it away from phones and phone lines sufficiently to stop the interaction. You could put hte phone in a RF proof bag (metalized film) which would then prevent it from receiving an incoming cell call. Either way, you lose some usability of either home or cell phone for the duration of the issue.
check Grounding Connection. Also check Security Alarm interface
Static (buzzing) on your line are produced from analog equipment in your phone system (your phone and phone cable). When the phone adapter receives the sound data, it digitizes the data and eliminates the possibility of producing static or buzzing. Try using a different phone or replacing the phone cable and test if that resolves the issue.
not hearing a dial tone.
If you do not hear a dial tone, please check the following:
• Make sure the telephone and VoIP telephone adapter are plugged in
• Disconnect and re-connect the telephone cable
• Make sure your telephone is set to ring (not set to pulse) If the above items have been checked, it is possible your phone adapter needs to be rebooted.
• Reboot your equipment as described in "Rebooting Your Equipment."
• If this doesn't work, try the solutions as described in "Calling Issues with Firewall/Router"
Take care..
Sep 20, 2011 | Uniden Cell Phones
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
How do i restore my harddrive to original settings wothout a disc
If computer is still working go to START, Program Files, Accessories, System Tools, Restore. Select an early date from its Calander and restore it to what it was like on that date. It will reboot and ask you several times if your sure.
Nov 08, 2009 | Dell Microsoft Windows XP Home Edition
I have an hp pavilion a1410y. the computers harddrive doesnot do anything but make noise so i installed two other harddrives out of other computers one of the harddrives has xp professional and the other...
The reason it wont boot from your other hard drive is because windows is expecting some different hardware on *********** bored, gets stumped and falls down.
On your computer there should be a license sticker. This will be rectangular with a green pattern on it. It will have your product key for what ever version of XP you are licensed for. You can place the drive which matches your version in your computer. Then, in order to get that install running on the new board, you will need an OEM copy of the appropriate windows disk. you may have received one with your HP, or talk to your geek friends who may have one.
to repair the load, boot off the cd. You will come to a window where you can press R (dont press R) for recovery console, F3 to quit, and Enter to continue. Then you will see a license. Press F8 to accept it. Then you will see a thingy that says "serching for previous versions of microsoft windows". Then it will show you the partions on the drive. select the OS one, usually marked "C". And there should be an option to press R for repair. Now you can press R. It will ask you for a product key. That is the one on the license on the side of the computer, also known as a COA (Certificate of Authenticicty). It will ask you for some other things too, like user names etc. Then you get to go hunt for drivers on the HP website. Lots of fun.
Sep 01, 2009 | HP Computers & Internet
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Brian
Jul 09, 2009 | Intel Computers & Internet
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Dail-up server doesn't answer from my home phone
What if you dial the same phone number from your phone instead of the computer. Do you get a ring...static sound? It could be a problemw ith your phone provider
Mar 09, 2009 | Dell Latitude D600 Notebook
Service was connected on Saturday 10/11, telephone rings in your ear when phone number is dialed, telephone not ringing inside the home.
If the caller hears ringing after dialing the home but the not ring inside home. That means the number is active but the wiring inside home is faulty/ not properly connected. A phone rings /or works of a basic system. Two wires usually red/green as primary. If either one is broken or improperly connected the phone inside will not ring. That doesn't indicate a short. If it was a short the caller would not hear ringing at all. So the first thing you must do is the track the cause. Make sure home phone is plugged securely into phonejack. Still no dial tone check all other jacks inside home. If still no dial tone. Contact your service provider. They will need to send a technician to check the Demarcation point. Which simply means the connection point where the service provider wires , meets the customers house wires. They just need to verify this connection
Oct 13, 2008 | Lands Phones
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
