Hi If the water inlet
valve is fine and it fills with water then the issue seems to be with the float
switch assembly that is bad and should be replaced. Float assembly is found
inside the dishwasher's tub, on the bottom. The water that fills the dishwasher
lifts the float, and when it reaches a certain level, it acts as a trigger for
the float switch. The float triggers the float switch to shut off, thereby
shutting off the flow of water into the dishwasher. A defective switch may
interfere with dishwasher's filling and/or draining ability. Use voltmeter to
test the switch. Set the device to the ohms setting x 1. Take each probe and
touch them to one switch terminal each. This should produce a reading of either
zero or infinity. Continue to touch the probes to the terminals, and press down
on the switch's button. The reading should change to the opposite extreme. If
the switch fails either of these tests, you should replace it. Hope this helps...please post back for
further assistance. Daniel
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
Here is a tip that
your dishwasher.
Dishwasher
heatman101
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
