Can't get internet and router to work together.
  • Steve Frost
    Steve Frost May 11, 2010
    Hello Gaylerawls.
    To help you further I need to know....
    1. What make of Router.
    2. What browser are you using.
    3. Is your connection via Cat cable or USB.
    4. What is your OS
    5. In your own words, please tell me what you see happen when you try and connect.
    When I get the information from you I will be able to help you further.
    Thank you.
  • Steve Rand
    Steve Rand May 11, 2010
    But internets LOVE routers!
    Scholar:
  • 45 Answers
Because you did not answer my clarification request I cannot really help you with this problem, and its safe to say that no one else could. However, the only thing I can say is to make sure that the OS is on Auto-Detect for the network connections. To do this, right click on the network connections icon and go to its properties and make sure the button is clicked....that MAY do it.
Posted on Sep 05, 2008
Please assist me as I previously had two Billon router connected to one network and this worked fine. Now I have two new routers one D-Link and the Other Net gear and I cannot seem to connect the two...
Take the second router out of the system and hook in a comptuter and see if you can communicate through that router. If you can then do the same for the other router. If you can get them to work independantly then hook them together and see if they work. Use the tracert command or ping to see if the protocol is getting through both routers. It can be difficult to set up both routers if one is not talking to the other one. You have to connect directly to the router that you want to change settings on.
Nov 04, 2013 | Computers & Internet
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have internet with the modem only, when I install belkin share router, I cannot access internet.
Is the Sync light on telling you the Belkin router is working, if not check your cables, i hope your not hooking the router and modem up together.
Nov 12, 2010 | Computers & Internet
Not connecting to internet
Did you try going into your network connections and deleting all the connections and putting the new one in manually?
That fix works for me all the time.
Oct 20, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like 192.168.1.2,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting a modem and router to my desktop
When you connect all the devices make sure you reset them all after plugging them together. Also use a different ethernet cord and make sure your plugging the Modem into the WAN port on the router. If your still having same problem just let me know.
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
