Question about Sony Cyber-shot DSC-S600 Digital Camera
"Access" and "Power on/off" screens
My daughters camera. She says she hasn't dropped or abused it in any way. Tried new rechargable batteries (2700mAh NIMH- 1.2V). Still getting the same error. Anyone got any other ideas, please.
  • cyber-girl Aug 25, 2008
    Managed to initialize the camera - no good (tried it twice)
    Did the power reset thingy - no good (tried it twice)
    The lens is still retracted behind the shutter so i can't tell if its crooked or not!
    Also tried the "carpet drop" - no good. The only thing is when dropping the camera in the switched on state, it powers off. Powering on again results in the same screen ie "Turn power off then on again".
    Very positive but did not do the trick !
    Master:
  • 848 Answers
What error is getting displayed?
Posted on Aug 24, 2008
  • gopinath pasupathy Aug 24, 2008
    lens mechanism not working properly so only it gives error, so camera says turn the power on. try to tap the lens while power up......
  • 435 Answers
What is the error message you get?
  • 3 more comments
  • Narmada Anand
    Narmada Anand Aug 24, 2008
    The solution seems to lie somwhere in the lens of the camera. Just try to adjust the lens, If lens looks a little crooked try moving it or putting it straight. Hope it helps.
    Then power off and then power on.
    Thanks. Please rate this solution.
  • Narmada Anand
    Sandra, were you able to iniliatize the camera from the MENU option?
  • Narmada Anand
    In that case, I suggest that you please try to POWER RESET the Camera and check if it works.
    Remove the battery from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.
    Thanks
  • Narmada Anand
    Were you able to power reset the camera?
  • Narmada Anand
    Narmada Anand Aug 26, 2008
    Thanks for the rating. In this scenario it is best to take your camera to the repair center and get it serviced.
    Please click on the link to locate the repair center:
    http://eservice.sony.com/webrma/web/inde...
    Put the date of purchase and your zip code.
    Thanks
Nikon Coolpix 5700 was working fine, now it won't turn on. Batteries are fine, but camera just won't power up at all. No error message, nothing but a dead (black) screen. No idea why it won't come on--it's...
Two quick suggestions first is the battery chamber contacts clean make sure they are clean. Are you using a battery pack with rechargeable AA's ? if so check the battery orientation it only takes one out of place. If you are using the rechargeable battery I know you said the batteries were fine but make sure the power is up on the rechargeable. I've had it where I put a battery on charge knowing it was pretty well dead came back 5 minutes later and the light was green, took the battery of the charger unplugged the charger plugged the charger back in and put the battery back on the charge. It then completed its true cycle.
Jan 04, 2011 | Nikon Coolpix 5700 Digital Camera
Batteries drained off too fast. New pair of batteries can only last for about 3 camera shots.
You don't say what batteries you are using. I believe this camera takes AA batteries, which come in many capacities. The best batteries for high drain applications are not single use alkaline cells, but high rated NiMH rechargeables. See if a pair of 2700mAh rated ones last longer than what you have been using.
Oct 14, 2010 | DigiLife DDV-C330/C340 Camcorder
Batteries go low too fast. New batteries can only last for about 5 camera shots.
Sony DSC-S600
If you have a memory card in the camera, take it out before turning the camera on
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Canon Powershot A630 problem
The LCD screen may be overtaxing your batteries, resulting in shutdown. Are you using alkaline batteries, or worse yet "super heavy duty" batteries? If so, some brands of regular batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Performance varies by brand and shelf life of the batteries (how long were they on the store shelf before you bought them? Their expiration date may be listed on the package.).
Digital cameras for the most part should only be used with rechargeable NiMH batteries. Many retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
May 16, 2008 | Canon PowerShot A630 Digital Camera
Polaroid i631 digital camera
Daughter received camera as Christmas gift. Camera beeps three times and does nothing. I guess this camera is only good until the warranty runs out, 90 days. We have tried several new batteries and the expensive rechargeable type also. VERY UNHAPPY!!!!!
Jan 31, 2008 | Cameras
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
88 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
