Question about Kodak EasyShare LS443 Digital Camera
Removing KES from auto-start
When I loaded this application, it automatically put an icon in the System Tray, thus auto loading it each time I start my PC. When my PC starts acting sluggish, I manually close the KES cause it's usually the culprit. How do I get the program to not auto launch upon every logon?
  • 114 Answers
I also use KES. Check your start up folder. You can safely remove it from there. It could have been worse, Kodak could have started it thru the registry!!! Good Luck.
Posted on Aug 30, 2005
Will only open tray # 4
Check its loading belt. Replace it.
Jun 05, 2012 | Philips MCM530 CD Shelf System
Loading Blackberry Desktop Manager in the System Tray
By default, setting up the Blackberry Desktop will cause the Desktop Manager to pre-load full screen each time the computer is started. To pre-load the manager application in the system tray instead, do the following:
  1. Open the desktop manager,
  2. Select the "Options" pull-down from the upper right hand corner.
  3. Check the option to "Hide when Minimized"
  4. Click "START > All Programs > Startup"
  5. Right click the Desktop Manager icon
  6. Select properties
  7. Under the Run option on the general tab pull down and select the word, "minimized"
The desktop manager will now load but only show when the Blackberry device is attached.
on Apr 08, 2010 | Cell Phones
Cyan and majenta tone is not good
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
My Memeo Auto-Backup does not start automatically with the PC. I have to go to START/ALL PROGRAMS to get it to load. It's been working fine for a couple of years, now suddenly it wont load automatically
Hi there!
The process for that application might have been removed from or disabled in the MSCONFIG startup file. To edit this, click Start>Run>Type: msconfig.
In the Startup tab, search for a process that is similar to or resembles the title of the application. You can also search by using the Command column by looking for the program folder the startup file is located in. Each entry will have it's corresponding company name in the path displayed. In this case that would be Memeo.
If that process is unchecked, check it and perform the same process within the Services tab - if the process has been disabled, the startup properties don't apply.
Click OK and you will be presented with the option to Restart or Exit Without Restart. To view the results immediately, restart and observe the behavior of the boot process. If the Auto-Backup doesn't load like it should, look in the Preferences section of the application and make sure "Launch application during boot" (or similar) is selected. Then restart once more to see what happens.
If the application still doesn't load, you may need to uninstall it and reinstall.
Hope this helps! Good luck!
Aug 19, 2009 | Computers & Internet
you need to unplug ever cable you have and every accessory you have. Unplug adapters memory units hd inter coolers every thing. let it sit for 10-15 minutes. Plug everything back in then press the button to open the tray to turn it on then put in a different game keep it open . Then when the menu comes go into a program so you can't see play game or close tray. Then when you are in the right place close the tray and it should load. This worked for me 2 times.
Jun 23, 2009 | Microsoft Xbox 360 Console
I have the officejet 6310 but cant use the scan feature, how do I get it to work
this is how you use the scanning features of your printer.
To use the scan features, the HP all-in-one and computer must be connected and turned on. The HP all-in-one software must also be installed and running on the computer prior to scanning. To verify that the HP all-in-one software is running, look for the HP all-in-one icon in the system tray at the lower-right side of the screen, near the time.
NOTE: Closing the HP Windows system tray icon can cause the HP all-in-one to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting the computer or by starting the HP Image Zone software.
For information about how to scan from the computer, and how to adjust, resize, rotate, crop, and sharpen scans, see the onscreen HP Image Zone Help that came with the software.
Scan an original
Follow these steps if the HP all-in-one is directly connected to a computer through a USB cable.
Load the original face down on the right front corner of the glass.
In the Scan area, press Scan To . The Scan To menu appears, listing destinations, including applications, for anything that is scanned. The default destination is whichever one was selected the last time this menu was used.
To select an application to receive the scan, use the arrow buttons to highlight it and then press OK or Start Scan . A preview image of the scan appears in the HP Scan window on the computer.
Make any edits to the preview image in the HP Scan window. When finished, click Accept . The HP all-in-one sends the scan to the selected application.
Send a scan to an HP Instant Share destination
Load the original face down on the right-front corner of the glass or, if using the document feeder tray, in the document tray.
Press Scan To on the control panel of the HP all-in-one. The Scan To menu displays.
Use the Up Arrow and Down Arrow buttons to highlight HP Instant Share .
Press OK or Start Scan to select the destination and scan the image. The image is scanned and sent to the selected destination.
NOTE: If an original is detected in the automatic document feeder, one or more pages are scanned. If no original is detected in the automatic document feeder, a single page is scanned from the scanner bed.
NOTE: For Windows users, the HP Image Zone software opens on the computer, and the HP Instant Share tab displays. A thumbnail of the scanned image will display in the Selection Tray. For more information on the HP Image Zone, see the onscreen HP Image Zone Help that came with the software.
Stop scanning
To stop scanning, press Cancel on the control panel.
May 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
My PS2 is having a wierd problem.
It is either a dirty or mis-alligned laser. It's best seviced by a repair shop.
Dec 18, 2007 | Sony PlayStation 2 (PS2) Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Kodak EasyShare LS443 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
