2007 Harley Davidson XL 883 Sportster Logo
Anonymous Posted on Jun 28, 2011
A lower bolt on the primary cover broke,so i removed the shifter and foot peg bracket,then removed all of the bolts from primary cover after draining primary fluid. The primary cover still doesnt seem to want to come off, i need to get the cover off to remove the broken bolt so that i can replace it. Inspection cover and cover by the clutch cable were also removed, what is holding this cover in place? (Sportster 883xl)
  • Anonymous Jul 02, 2011
    thanks i will go to bikebandit.com and check that out. You are absolutely correct the engine cases are two halves put together w the split being lengthwise. When i originally wiped the oil off the bottom of the bike to see where the oil was coming from, this is where i noticed what appeared to be a fine bead of caulk come out from in between the engine cases. I will also work on sending a picture of the bottom of the engine cases.thanks again!!!!
    thanks again for all your help,i hope to have everything put back together by the end of the day, after i go for a ride ill definitely try the talcom powder and let you know what i find. Ralph
Anonymous
Level 3:
Brigadier General:
  • Master 4,565 Answers
  • Posted on Jun 28, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4565
Questions
0
Helped
2156165
Points
14358
You need to remove the derby cover from the primary that goes over the clutch adjuster. Remove the sping and the locking nut. Turn the adjuster screw clockwise while gently pulling the cover off. The cover should come off then.
Good Luck
Steve
  • 1 more comment
  • Anonymous Jun 29, 2011
    Thanks, i got it off!!!!,i just recently changed the exhaust and air intake from stock to vance and hines and arlen ness. I managed to get @55 HP n 51 ft lbs of torque out of a bike that started with @40 HP. I know its a Harley but is there any way to keep all the bolts tight all the time,i can see where the tranny meets the mtr. a bead of caulk? coming out from in between them,should i try to tighten these bolts and if so how tight do they have to be?
    On a Sportster, the engine and transmission are what we call "unitized". This is a term that us old guys use to describe an engine/transmission setup in a bike. It comes from the early British bikes. Prior to 1972 or so, the British bikes had a seperate engine and transmission connected by a primary drive case like the Big Twin Harleys do even to this day. Later, they went to an engine/ transmission design that was all one piece or "unitized" like most of the *** bikes. The Sportster has always been like this since their introduction in 1957. The point I'm trying to make is that I don't understand your statement of ",i can see where the tranny meets the mtr. a bead of caulk" The tranny does not meet the motor on a Sportster. The engine cases are two halves put together with the split being lenghtwise or down the middle of the engine cases. Go to this site and look at how your engine is put together. http://www.bikebandit.com . If you can, please take a picture and send it to me at [email protected]. Make sure that the view is wide enough so that I can get a reference of exactly where this bead of caulk is. There should not be a bead of caulk visible either inside or outside of the engine cases. To keep the bolts tight, use Loctite 242 med. strength blue on the bolts. Some places you can use the high strength red but I don't advise it unless the bolt is threaded into steel instead of aluminum.
    Harley does use a sealant on the cases when they put them together but most of the time that get any excess that squeezes out off before the engine goes into the frame. Maybe someone got a little sloppy that day or it was almost time to go home. At any rate, the Sportster engines usually do not leak in this area. Most of the time when you see oil in that area it has run down to that area from somewhere else. You're on the right track. Clean the bottom of the engine off as best as you can and go for a short ride. When you get back. look for the oil. If you see it. you can use some talcum or foot powder to "dust" the bottom of the engine case. The powder will stick to the case anywhere there is oil and you can see where the oil came from and once you've finished, the powder comes off easily. If you had a broken bolt on the primary cover, this could have been the source of the leak. When riding, the wind blows the oil around on the bottom of the engine as well. Good Luck. Steve
How do I replace starter on 2002 sportster
First disconnect the battery cable. Then you'll have to pull the primary cover off the engine. Find the primary case drain plug underneath the rear of the primary case and remove it to drain the oil. Find the primary chain tensioner underneath the primary cover near the center and loosen the locknut. Turn the screw downwards to loosen the tension on the primary chain. Remove the left foot peg and take the "derby cover" off of the primary cover. Remove the spring and lock nut underneath the derby cover. Remove the bolts around the primary cover. As you gently pull the primary cover away from the engine, turn the clutch adjuster screw under the derby cover in a clockwise direction until the primary cover comes off. Remove the battery cable where it bolts onto the starter motor and the small single wire that plugs to the motor. Just above the clutch assembly there are two bolts. Remove these bolts and the starter will come off the engine. The bolts are different lengths. Make sure you mark which bolt goes where.
Good Luck
Steve
Need to know how to get off outer primary cover off of 1979 harley davidson
Lower the primary chain adjuster under the primary but loosening the locknut and turning the adjuster screw downwards. Take the large nut that holds the foot peg on off. Take all the bolts out around the primary. Take the round inspection cover off at the clutch and remove the spring and lock nut out. Turn the clutch adjuster screw in there clockwise until the primary cover comes off.
Steve
1helpful
How to change my stater
To change the starter on your Sporty, first disconnect the battery. Remove the exhaust system and anything else that it is the way of the starter. Take the battery cable off the starter. Then go to the left side of the bike and remove the foot peg and shifter. Loosen the lock nut on the primary chain tensioner on the underside of the primary. Turn the adjuster screw out a few turns. Take the derby cover off and remove the spring and lock nut on the clutch adjuster. Then drain the oil out of the primary by removing the plug on the underside of the primary. Remove the bolts that hold the primary on. As you pull the primary cover away from the engine, turn the clutch adjuster screw in the center of where the derby cover came off in a clockwise direction. The primary should come off as you turn the screw. Once the cover is off, lay it aside. Remove the two bolts located directly above the clutch assembly. They are different lengths so make sure you remember which goes where. Once these two bolts are out, the starter will come off.
Good Luck
Steve
I have a 75 flh with the passenger peg mounted to the primary inspection cover.is this stock. if not where do they mount
Yes, this is where the passenger foot peg on the left side of the bike goes. There is an arm that clamps onto the round stub on the inspection cover and is afjustable to almost any angle. The right side foot peg support bolts to the end of the transmission and also has an adfustable arm that clamps onto a stub on it. Then the pegs go on the end of the arms. Go to this site and take a look . http://www.bikebandit.com/1975-harley-davidson-flh-1200/o/m770#sch171752 I'm pretty sure they didn't move the peg brackets to the seat tubes of the frame until 1977. If your bike has two holes in a welded-on tab on the rear of the down tubes behind the primary and the transmission, you can use the later model peg brackets. But, if your bike has no holes in the frame or the swingarm for passenger peg brackets, this is the only style you can use and stay original. You could fabricate and weld on tabs to later model peg brackets or use clamp on brackets and pegs.
Good Luck
Steve
Removing primary cover on 04 1200c
To remove the primary cover from you Sporty, you'll have to remove the shifter and foot peg. Then loosen the locknut for the primary chain adjuster and turn the adjuster downwards to loosen the primary chain. Then remove the plug at the bottom rear of the plug to drain the oil from the primary. Remove the clutch release mechanism cover from the outer primary. Remove the spring and locknut. Turn the clutch adjuster screw as far clockwise as you can turn it. Then remove all the bolts around the outside of the cover. While pulling the outer cover gently away from the engine, turn the clutch adjuster screw clockwise until the cover comes off.
Good Luck
Steve
2helpful
Is it hard to change the primary gasket on my sportster
No, just drain the primary. You'll have to take anything like shifters, foot pegs, and other stuff that might be in the way off the bike. Then, go underneath the primary cover and loosen the locknut of the primary chain tensioner and turn the screw downwards to remove the tension for the tensioner. Now, take the derby cover off and remove the spring and the locknut. Take the bolts out of the cover and then turn the clutch ajuster inwards as you pull the cover off. The cover will come off.
Then to install the cover, hold it up to the clutch adjuster and turnt the screw counterclock wise as you put the cover back on. Put all the bolts in the cover and tighten them. Then back at the clutch adjuster, turn the screw outwards until it stops. Then turn it back inwards 1/4 turn, put the locknut and the spring in and replace the derby cover. Remove the top plug of the primary cover. Stick you finger in and feel the up and down play of the primary chain. Adjust the bolt at the bottom of the primary upwards to reduce the play to about 1/2" to 5/8" and lock the lock nut. Refill the primary with one quart of primary-transmision lube. Replace anything else you have taken off the bike.
good Luck
Steve
How do you take out the starter?Does the engine has to be taken off the frame?.
No, the engine does NOT have to come out of the frame.
First, disconnect the battery. Drain the primary cover, remove the shifter, foot peg, loosen the primary chain adjuster under the outer cover, whatever needs to be removed depending on your model Sportster to get the primary cover off.
From the right side of the bike, remove the exhaust system and whatever you need to remove to get the starter off. Disconnect the large battery cable and the single wire from the starter.
Back on the left side, there are two large bolts just above the clutch assembly, remove them. They may be different lengths so watch for that. Remove the starter.
Good Luck
Steve
5helpful
Clutch cable broke at handle lever on 1979 harley davidson sporst
To change the clutch cable on you '79 Sporty, you'll have to take the outer primary cover off. To do this, you'll have to drain the oil from the primary, take the left side foot peg off, and loosen the primary chain adjuster on the bottom side of the primary. Loosen the locknut and use an allen wrench or hex key to screw the adjuster bolt downward.
If you need to know anything else, drop me a line at [email protected]
Then, remove the large "plug" towards the rear of the cover. Inside, you'll see something that looks like a nut but with no threads in it held in by a small spring. This the the lock nut, remove it. Below it is what looks like another nut with a slotted adjuster bolt sticking out. Remover the bolts from around the primary cover and break it loose from the engine. While turning the adjuster screw at the rear of the cover inward, remove the cover.
The cable connects to the cluch release mechanism. By turning the "link" downwards, you can disconnect it from the mechanism. Notice which way the "link" in attached to the release mechanism. Take the "link" off the end of the clutch cable.
Break the lock nut loose at the threaded cable adjuster on the outside of the case and screw the adjuster all the way out of the primary cover. Disconnect the cable at the handlebar lever and your cable is out.
Reinstall the new cable in the reverse order. When replacing the outer primary cover, make sure you use a new gasket on the cover as well as on the foot peg boss. The "foot peg boss gasket" is very important. You'll see an aluminum boss with a threaded rod sticking out of it that holds your left foot peg on. There is a round gasket that goes over this threaded rod and seals against the boss. If you leave this off, your bike will leak oil around this threaded rod when your foot peg goes on. Make sure you specifically ask for the "foot peg boss gasket" when you buy the new primary gasket. It's just a round gasket a bit larger than a quarter.
As you put the primary cover back on, there is a spring on the primary chain adjuster. Part of the spring is in the primary cover and the other part is in the engine. You'll see how it goes in. There is a large stud in that area that the outer primary cover slides up on. Adjust the tension on the primary chain by removing the "plug" at the top of the primary cover. You want 3/4" to 7/8" up and down play in the chain with the engine cold.
On the adjuster, as you're installing the outer cover, turn the ajuster screw back into the clutch release mechanism by turning the screw backwards. Once you have the outer primary cover completely installed, you must adjust the release mechanism. Adjust the screw inwards until you feel a resistance, then back the screw off about a 1/4 to 1/2 turn, insert the "lock nut" and spring, and install the "plug". Then, using the cable adjuster on the outside of the cover, adjust the cable. Add oil.
2answers
Engine oil change
should be lower, but may have been switched; drain both, you're doing a service!
Foot peg bracket removel 2000 sportster
you must remove pulley cover and master cylinder. inside cover is a large nylock nut holding peg mount. once removed a bolt and nut should be replaced in its place as it holds some of master cylinder
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
