Question about Roper MHE14XKB Microwave Oven
Need to uninstall
How in the world does this OTR microwave come out?
  • Roper Master
  • 9,098 Answers
If your model is an MHE14 type, you can download the Installation Instructions here.
If yours is a different model, enter your model number here.
Posted on Aug 24, 2008
I'm trying to convert a over the range frigidaire microwave that is 30" by 15.5" by 15" into cubic feet.
generally speaking you buy and OTR microwave by width, i.e., 30" wide is the standard width of all most all OTR . so any 30' wide microwave will fit. when talking about cubic feet, they usually are talking about the interior capacity of the microwave. but if you really want to know cubic feet of above dimensions, then multiply all three together and divide by 1728. (4.036 cuft)
Aug 29, 2015 | Frigidaire Microwave Ovens
Bulb replacement
Is it an over-the-range (OTR) microwave or a countertop microwave? If it's an OTR microwave, are you talking about the light(s) on the bottom of the microwave, or the one that lights up the cavity when you open the door or run the microwave?
If it's an OTR microwave, and the cavity light is burned out, you MAY be able to access it by removing the grill vent by removing the 2 to 4 screws above it. Then, depending on the model, either slide the grill vent to the left and pull it out, or else pull out the top part of it first. Then, if there is one, you may see an access cover behind the grill vent. Unplug the microwave, then remove the 2 screw that holds the access cover in place, and lift up and remove the cover. You should now be able to get to the light bulb.
If it's a counter-top microwave, you will have to remove the complete cover by removing the screws on the back, and possibly a couple of the sides. Note, 2 screws are special security screws to prevent the casual customer from fixing his own microwave oven! UNPLUG THE MICROWAVE FIRST, then remove the cover screws. Slide the cover back about 1/2 inch, and then it should come completely off. You should now be able to see the light bulb to change it. Then reverse the process to put the cover back on. I hope this helps.
Oct 21, 2014 | Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Can I replace a 1.3 cu ft otr microwave with a 1.5
Brackets can remain the same throughout a particular brand for several years but will also change every year at times. Same year and same brand, I would say yes. Different year of manufacture or different brand name I would say, no it will not fit the existing brackets. If you have a particular brand in mind and have the model number of the existing OTR, it is usually possible to search out installation instructions for both at the manufacturer's website. You could then compare to see if they will match up. The two screws through the upper cabinet floor into thr top of the OTR can vary, within a particular brand even in the same year of manufacturer.
Mar 14, 2010 | Microwave Ovens
Samsung otr microwave vent quit working
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here.
Jul 20, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LED displays ''STAGE'' after magnetron replacement on DANBY DMW162W-OTR
What does the service center have to say about this?
Or did you do it yourself?
Dec 01, 2007 | Danby DMW139 Microwave Oven
Roper MHE14XKB Microwave Oven Logo
201 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
bigdawg7299
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
