Question about Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD-52527 Lamp problem
Lamp LED is steady red. I obtained and replaced Bulb with Philips 915P028010. Turn set on, indicator LED flashes green.Then a momentary steady green, then turns steady red.Manual says reset lamp timer with TV menu but can't access with no picture..What next ?
  • 1 more comment
  • Anonymous Jan 13, 2009
    My Mitsubishi WD52527 TV has a poor picture quality. The picture is kind of foggy. What is wrong?
  • tbrandish Apr 10, 2009
    I have the same problem.
  • ilevine Apr 11, 2009
    3yr old 51" mitsubishi WD-52527. picture poor - dim, not sharp. lamp replaced less than a year ago. any way to reset back to factory settings?
  • 39 Answers
SOURCE: Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Posted on Nov 30, 2007
SOURCE: Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Posted on Nov 02, 2008
Slinteriors
  • 8617 Answers
SOURCE: Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Posted on Mar 15, 2009
  • 68 Answers
SOURCE: were to but mitsubishi lamp 915P028010
TRY ENCOMPASS.COM THEY HAVE SEVERAL SELECTIONS AND DIFFERENT PRICES
Posted on Oct 02, 2009
  • 5 Answers
SOURCE: I replaced the lamp in my Mitsubishi model
You may just need to reseat the lamp in the holder.
Posted on Dec 29, 2009
I have a mitsubishi projection tv. I need to replace the bulb. Does any one know the difference between a pure glare bulb and a osram neolux bulb? Which bulb is right product for my tv? Also, which bulb is...
When in doubt check with sites such as www.TvRepairKits.com - check their online store first then email them if they do not show it. In most csases OSRAM is a great lamp...nore sure about pure glare...
Feb 22, 2013 | Philips 915P028010-P Projection TV...
SCREEN IS BLACK ,BUT HAS SOUND
this is most likely just a lamp issue this lamps a made to last a average life span of 2-3 years of use
replacing the lamp should fix your problem that is the first thing to replace in this cases
here are few good online stores that have the lamp you need
http://www.discounttvlamps.com/915P028010-Housing-p/mitsubishi-915p028010-enc-ph.htm
http://www.discount-merchant.com/Mitsubishi-915P028010-915P028A10-Lamp-Enclosure-p/mitsubishi-915p028010-lamp-enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Nov 05, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Were to but mitsubishi lamp 915P028010
Oct 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD52527 52" Projection HDTV Logo
445 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
