Question about D-Link DMF 560TXD (DMF-560TXD) Modem
DMF 560E The problem started one day due to lightning and thunder storm, The following leds are glowing the moment I on the modem: PWR, MR and HS. Once I connect the dialup line to LINE socket and telephone instrument to PHONE socket and lift the phone the dial tone slowly dies out. Please help me out. Alok Agrawal
    New Friend:
  • 22 Answers
Did you have it plugged into a surge protector? If yes you may be able to do a hard start. I’m hoping it’s not a blown capacitor issue. If it is you’ll have to take it to the repair shop. Try these steps first and see if it will work. Power everything off and unplug it to include your internet modem. Wait 30 secs and plug it back in and restart everything. Hit control,alt, delete at the same time and hold it for a few seconds. It should then show you a screen asking you if you want to reboot. Hit yes and follow any instructions given. Then test your phone line again.
If it’s still not working, try unloading, then reloading the program. Make sure all your updates for the computer are completed. Check the cord, see if the power surge fried it. If it did. It’s an easy fix. Just buy a new one. All so try plugging it in to a different outlet. That way you make sure the problem is not with your outlet. If nothing above works then you’ll need to take it to a repair shop.
Posted on Dec 19, 2017
SOURCE:
  • 138 Answers
SOURCE: D-Link adls modem - interference with telephone
Yea this type of happen with most of DSL users! This is due to weak signal telephone line. You should only have 1 phone and 1 internet connection. You should remove all other telephones in the home. Then it will work fine. If you only have 1 phone then you must call the phone service person who will check that status of your wire. Might be your wire is old so it creates a problem. Then replace it the you'r done.
Posted on Dec 11, 2007
  • 214 Answers
SOURCE: NODIALTONE
go to the modem properties and un check the wait for dial tone tab
Posted on Jul 24, 2008
  • 113 Answers
SOURCE: Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
Posted on Nov 03, 2008
  • 58 Answers
SOURCE: i have d-link 560e modem and i want at command to
If the software that you are using with the modem does not have the ability to set the modem to autoanswer you will need to configure the modem manually. You will have to use Hyperterminal to enter the command into the modem's memory.
(if you do not have Hyperterminal installed please add it by going to Control Panel > Add/Remove Programs > Windows Setup > Communications > Details...)
Have the modem connected to your computer and ensure that it is working fine. Go to:
Start > Programs > Accessories > [Communications] > Hyperterminal .... Hyperterm.exe > name the connection "modem" > Connect Using... Select COM3 or COM4 (on whichever port the modem was assigned to) > Bits per second 9600 > OK.
After that try typing ATZ command and press ENTER (you may not see what you are typing). The response from the modem should be OK.
Apply the following command:
ATS0=3
Now write the new settings into the modem's memory by typing the following command and pressing Enter:
AT&W
The response should be "OK"
The modem will now be set to auto-answer after 3 rings.
Posted on Jun 21, 2009
  • 94 Answers
SOURCE: how to connect DFM-560E to system or hp laptop
Check their site
http://www.dlink.com.au/tech/faq/modems/dfm560e.htm
Best to connect via lan cable, not usb.
Posted on Apr 19, 2010
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Apr 12, 2014 | Whirlpool Refrigerators
My tv was hit by lightning is it fixable
When tvs are struck by lightning most of them are beyond repairs and if successful they always give problems in the future.
Jan 10, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Lightning storm
More than likely the module/chip got fried by a voltage/lightning spike.
It's cheaper to replace small appliances than to repair them.
Suggest buy a new one.
Nov 02, 2017 | Coffee Makers & Espresso Machines
I own an LG 42LB1DR-UA. After a major lightning and thunder storm last night, I see that there is no voice when watching cablevision which is hooked up with HDMI cable. When I use other cable [3 color], I...
Sir try to use a dvd and put a movie if your unit produce normal sound and picture the problem is the digital receiver. Good day and best regards.
Aug 19, 2011 | LG Televison & Video
I have a nintendo 64 that turns on and has sound but no video output. I have tried 3 different connectors including a gamecube one that has always worked with my gamecube and still does. Is there anyway i...
Well I think that the console might of had been damaged by lightning thats why when theres a thunder storm you should always unplug your consoles so they won't get hit by lightning I always unplug mine when theres a thunder storm. Well the sound module inside of the console is broken then so you could send it into console solutions then they repair old systems too.
Aug 16, 2011 | Nintendo 64 Console
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
How to connect DFM-560E to system or hp laptop
Check their site
Apr 19, 2010 | D-Link DFM 562E (dfm-562e) Modem
Cox says my SB5120 is resetting 12 pulse times a
May be firmware get corrupted due to power-cut or an excess voltage or surge problem.
At times when there is thunder-storm a lot of excess volatge is generated on the phone wire which is link down to the modem
Ok
try to download recent firmware from manufacturer and see if it can be updated.
Cheers
Uttam
Jan 14, 2010 | Arris SURFboard SB5120 Modem
My laptop could not connect to internet through dial-up modem
it might be your MODEM is defective due to lightning storm apperance, you should try another MODEM to connect on the internet.
Jul 21, 2009 | Computers & Internet
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
-\&;-WINDSTREAM Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This windstream USA phone number is ranked #2 out of 2 because 7,728 windstream USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the windstream USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, windstream USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. windstream USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact windstream USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling windstream USA Calling windstream USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from windstream USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with windstream USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare windstream USA's phone numbers against each other. Contacting windstream USA in General While I8OO8280294 is windstream USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach windstream USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact windstream USA.
Oct 16, 2019 | Best Computers & Internet
AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr AVAST cUsToMeR SuPpOrT PhOnE /@\{1888499/@\5520} NuMbEr
Oct 16, 2019 | Computers & Internet
See all D-Link DMF 560TXD (DMF-560TXD) Modem Questions
D-Link DMF 560TXD (DMF-560TXD) Modem Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
