Question about Nikon D70 Digital Camera with 18-50mm Lens
Shadow on image when using built-in Speedlight
I sometimes get a round, dark area on the bottom of my pictures when I use the built-in flash. What is this caused by and how can I remove it?
    Novelist:
    Scholar:
  • 79 Answers
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Posted on Aug 30, 2005
We just bought d90 nikon camera and we found a small half-round shadow at the bottom of the pictures taken when we dont use the zoom lens, how do we correct this?
Are these pictures taken using the built-in flash and with the hood on the lens? If so, you're seeing the shadow of the lens hood.
Remove the lens hood when using the built-in flash.
Sep 17, 2009 | Nikon D90 Digital Camera with 18-105mm...
When I take a photo with my Nikon D90 in auto mode and flash i get a dark spot on the bottom of the image on the lcd that resembles a shadow. there is no shadow in the picture. What is casuing this?
This is more than likely a shadow from your lens. The on-camera flash is in a fairly low position, and I am able to duplicate your description when using my D200 on-camera flash and a physically longer lens- in my case a 28-70 F2.8 lens. Using a hot-shoe mounted flash will clear this issue up completely and give you more control options as well. Worth the money that one costs, in my opinion.
Jul 11, 2009 | Cameras
Nikon coolpix 4800 - built-in flash may need to be replaced
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Mar 05, 2009 | Nikon Coolpix 4800 Digital Camera
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Flashes but image is dark
Turn the front black knob and check to see if the front window is not dirty.
atdlee@netzero.com
Mar 18, 2008 | Vivitar 283 Flash
Shadow on image
The camera has a main mirror that you see with the lens off and a sub-mirror underneath the main one. It may be the sub-mirror is not flipping up completely when you take a picture. It could be off its hinges or damaged. Any good camera repairman in your area should be able to confirm this
Dec 26, 2007 | Nikon D80 Digital Camera with 18-135mm...
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
http://www.diyphotography.net/diy-built-in-pop-up-flash-diffuser
http://www.flickr.com/photos/natuurplaat/10362363/
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Does Nikon D70 come with an additonal bottom to plug in Bowen Flashfill
Are you using the built in speedlight on the camera with the lens hood fitted? If you are this will cast a shadow. Try removing the lens hood when using the pop up flash.
Nov 27, 2007 | Nikon Speedlight SB-600 TTL Flash
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
259 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
