Question about HP OfficeJet k60xi InkJet Printer
I am to send a fax with my K60xi but I cannot receive a fax. Do you have any suggestions?
4 Suggested Answers
SOURCE:
hashir4u
  • 79 Answers
SOURCE: Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
Posted on May 23, 2008
frcs68
  • 1605 Answers
SOURCE: can't receive fax
go to:
1 On the control panel, press menu/enter.
2 Using the < and > buttons, select Fax Setup, and press
menu/enter.
3 Using the < and > buttons, select Fax Recv. Setup, and press
menu/enter.
4 Press menu/enter to select Answer Mode.
5 Using the < and > buttons, select Automatic or Manual, and press
menu/enter.
6 The control panel display shows the answer mode setting you
specified.
I also attached the link for the laserjet 3300 users manual
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/bpl11457/bpl11457.pdf
Posted on Oct 28, 2008
  • 163 Answers
SOURCE: cannot receive faxes but can send them
auto answer should be on
Posted on May 04, 2009
The fax receives but i cannot send fax?
I would suggest you to try Popfax.com internet fax service. I use it for several years, and never got problems. It is cheaper than other providers. Try it for free on FreePopfax.com.
Jul 24, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
My fax machine wont send or receive faxes any suggestions?
If it is properly connected to the jack in the machine and the wall, and it won't send OR receive...then it's NOT a simple problem, because nothing else need be done for the machine to at least "send" a fax.
Dec 15, 2009 | Ricoh FAX1180L Laser Fax
Having trouble sending a fax and receiving one,, also where does
To send a FAX load the pages in the auto feed tray on the top of the unit. To receive a FAX, load the paper in the paper feeder vertically on the back of the unit. Suggest you consult your users manual.
Jan 19, 2009 | Epson Stylus CX9400 Photo Printer
Fax Problem
Apr 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
HP OfficeJet k60xi InkJet Printer Logo
22 people viewed this question
Clive
Clive
Thomas F. Schneider
