Question about Samsung Televison & Video
Could you plaese tell me where the dvd entry point is on the samsung le22s86 tv ie side left/right or top load many thanks
Posted on Aug 24, 2008
My Samsung TV developed a a single blue vertical line on the left side. what could possibly cause that.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 13, 2015 | Samsung UA-40H5500 40" Full HD Smart...
Service mode tv samsung model cs 29z57mh
Service mode entry option to different models to this TV will differ to each other. If you wish to get more details, check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Oct 19, 2013 | Samsung Televison & Video
How do i unlock my washer there is no code and the power bottom won't go on plaese tell me what to do?
is the machine full of water if so take the discharge hose out of the stand pipe and empty the water in a bucket low to the ground once the water has empty you should be able to open the door if not tilt the machine back and try then clean the blockage ie pump or filter anymore help let me know
Nov 24, 2011 | Samsung WF203ANW Front Load Washer
I am have trouble getting the sound to work on my memorex mihts3202 I am hooking it to a samsung LED
I had this same problem. I thought I had to return the device, but it turns out that I made a very amateur mistake. To test to see if the device worked I hooked it up through my DVD player, and it had worked perfectly.
You need to plug the one ends of the audio cable into the Memorex Mmihts3202 on the "TV" side of the LEFT and RIGHT plugins ( as there is also a "DVD" slot for LEFT and RIGHT audio above ). Then, insert the other ends into you're cable box ( ie. comcast box, verizon box ) or whatever box/system you use.
Worked for me! :)
Sep 19, 2009 | Memorex Televison & Video
Samsung LE22S86 does not have good dvd images
If you go to the samsung website for uk at you can search for that model and download the manual in pdf format. If my link pastes OK, here is where you want to go:
good luck.
Sep 04, 2008 | Samsung Televison & Video
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
Dvd stuck in the dvd / tv
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
Jan 18, 2008 | Polaroid 3211TLXB 32 in. LCD Television
My TV is not working! Please help!
Sony Convergence
Dec 22, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Hitachi 43FDX15B color convergence problem
Sony Convergence
Nov 10, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
My dvd player stopped working and all i want to do at this point is remove my rented dvd.
If you just want to take out a DVD here's what to do:
1.Take off the top cover:
- remove five screws on the back (indicated by little arrows)
- remove two screws on each side (there are only two, this should be obvious)
- when looking at the back of the unit, slide it up and towards you.
You should now be able to see your DVD. However there is a piece covering it.
2. Take off the top of drive:
- remove two screws, (one on each side). They are very small (probably black) and on the top of the cover, on the far left and right. They might be hidden under small rubber squares. If so, just peel the squares off.
- The cover should come right off.
- lift out the disc
3. Reassemble
good luck,
Oct 25, 2007 | Memorex MVD2042 DVD Player
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
