I have a phillips rear projection tv. the convergence on the red is of really bad.
    Genius:
  • 2,920 Answers
Your convergence boardmay be out
Posted on Aug 23, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
My phillips 51'' rear projection tv has red and green shadows on it
The convergence is off on the tv more than likely. Check the owners manual on how to adjust convergence or call the manufacturer they are good about walking their customers through the steps to fix convergence. You can also press the menu button or try another source such as a dvd player and/or a gaming system. If other sources have the same issue it's for sure the tv.
May 07, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Red will not converge even after I replaced both IC's. Please Help ASAP!
I have a phillips in my office like this. There are a few things to check. Check the resistors around the red convergence ics it is probably open resistor or resistor fuse take your time and check all the resistors.In rear cases it could be the surface mount ics on bottom of convergence board i hope that is not the case.
thanks doctor video leading edge electronics
May 08, 2008 | Philips 43P8341 43" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Phillips 55pp9401 red and green not converging even after using itellesense
Replace convergence IC's STK392-110 mounted on large heatsinks....I use upgrade STK394-160E = CZ 01341 Hitachi #.
Let me know if you have ??'s.......................T.
Oct 27, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
