Nikon Coolpix 3200 Digital Camera
Problem for Nikon Coolpix 3200 Digital Camera
"Nikon software does not run on this Operating System" Error Message
By Guest on Aug 30, 2005
When trying to install Nikon software I get the message that "Nikon Capture does not run on this Operating System"? I am using Windows 98SE, which is an approved OS, what is wrong?
Best Solution
posted on Aug 30, 2005
Very Helpful)
James Maynard
Rank: Wiz
Rating: 82%, 65 votes
When attempting to install Nikon Capture or PictureProject on certain Windows 98SE systems the following error messages may present themselves:
This message is caused by the registry key value for the "SubVersionNumber" on the version of Windows. If the system contains SubVersionNumber "B" Nikon Capture and PictureProject will not install on the system. Below are instructions on how to manually edit the System Registry to change the SubVersionNumber Registry Key to allow for Nikon Capture and Picture Project to install.
Manually editing the System Registry requires vigilance and care because a mistake could cause errors with the System. Be extremely careful when editing these keys. Nikon is not responsible for any loss due to problems with registry key editing.
To manually edit the System?s Registry:
1) Quit all running applications
2) Click on "Start" then "Run?" Type the following in the run command line: "regedit"
3) Click "OK" and the registry editor will open
4) Click "Edit" from the menu bar and choose "Find"
5) Type "4.10.2222" into the "Find What:" field
6) Click "Find Next"
The results will appear in the column on the right. The Version Number will be highlighted.
7) Click on "SubVersionNumber" once.
8) Go to "Edit" on the menu bar and choose "Modify"
9) The current Value data will read B.
10) Change "Value data" to " A" (MAKE SURE THERE IS A SPACE BEFORE THE A)
11) Go to "Registry" in the menu bar and choose "Exit"
12) Confirm the change has taken effect. Right-click on "My Computer", choose "Properties".
13) The version value should reflect "4.10.2222 A"
Nikon Capture and Picture Project can now be installed and run on this system.
You rated this solution as "Very Helpful".
Popular Solutions for Nikon Coolpix 3200 Digital
Questions and Unsolved Problems for Nikon Coolpix 3200 Digital
Do you recommend Nikon Coolpix 3200 Digital Camera?
Answer
Answer
lens not retracting; unable to power on/off; changed out batt.; intermittent green light flash from... (More)
Answer
I have a nikon cool pix 3200, my problem is that it takes a long time before my camera is ready to... (More)
Answer
my pc won't install the cd software. How do I download my photos from my Nikon 3200?
Answer
i have a coolpix 3200,2200 camera and cannot find my picture project software, is there somewhere i... (More)
Answer
I have a coolpix 7900 with a broken battery door, is their a reasonable price to fix it ?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon Coolpix 3200 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
