Question about Dell Latitude C640 Notebook
NO BOOT DEVICE AVAILABLE
In the bios under boot device it says it is not present. however when it boots, just before i get the "no boot device available" it lists the drive "RAID Volumes"
and it lists "Bootable" Also shown is "Physical Disks" a "0" and '2" is listed along with some other information
    Genius:
  • 2,028 Answers
If you hit F12 at start up it will go to the boot menu. In this menu it should list the hard drive and the CD drive, if it doesn't, then this could be a simple bios glitch, in which you will need to make a floppy with the bios download from Dell's support site in order to flash the bios, using a floppy drive. It's not likely that both the hard drive and CD drive went out at the same time, which is usually what the "no bootable device" means, unless this is a machine that you just purchased and don't know anything about. I've gotten a few off Ebay that they slid bad drives into, just to make the sale. Try the bios flash and get back to me if it doesn't work.
Posted on Aug 24, 2008
SOURCE:
I added a second sata hard drive to the the computer and now the computer does not see, either one. When I try to boot it says no boot device available. When I look in the bios version a11, under boot...
Is it booting from Second HDD without installing the first HDD. If it booting then shutdown the system and now install the first HDD. If it boots then good and if not then the SATA port on the board have damaged need to repair that.
Oct 09, 2013 | Computers & Internet
How do i get my HP pavilion 521n to boot DVD ?
  • Press the "F1" or "F10" key when the logo appears on the screen to enter the BIOS setup.
  • Navigate to the BIOS menu "Advanced" using the right/left arrow keys on your keyboard.
  • Get to the option "Boot Order" with up/down arrow keys, and press "Enter."
  • Select the first boot device under the "Boot Order menu option and press "Enter."
  • Select "DVD" from the list of available boot devices and press "Enter."
  • Press the "F10" key to save your changes and exit the BIOS setup. The computer will automatically restart and then will boot from the DVD.
  • Aug 05, 2013 | Computers & Internet
    Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
    Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
    If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
    Apr 03, 2013 | Computers & Internet
    Can Gateway MX3215 boot to usb stick?
    If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
    If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
    Nov 13, 2011 | Gateway MX3215 Notebook
    Wont boot ms 6567 from cd/dvd
    1. Try to go to the BIOS 2. under the Advance BIOS Features---> go to Boot Device Priority 3. under Boot Device Priority -----> make CDROM as the first boot device 4. let the 2nd and 3rd boot devices as Disabled 5. Press the Esc key 6. Choose the save and Exit option 7. Make sure the cd is in and restart the computer
    Thanks for choosing Fixya
    Jul 18, 2011 | MSI 645E Max2 (MS-6567) Motherboard
    I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
    During the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
    (note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
    The BIOS is AMI. Under ADVANCED SETUP:
    The options listed for 1st,2nd ,3rd Boot device include:
    IDE-0 means Pri master ?
    IDE-1 means Pri slave ?
    IDE-2 means Sec master ?
    IDE-3 means Sec slave ?
    hope this helps
    Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
    Error pxe-e61 media test failure
    download new drivers for it, it can be registry error run registry cleaner reg in out may solve the problem
    Sep 15, 2010 | HP Pavilion dv1000 Notebook
    When compuetr starts no boot device available but BIOS seen
    If there is no HDD or any other boot device the BIOS will always be present. This problem occurs if you haven't installed any Operating System on the HDD. So when the computer is booting it finds no booting device files and that's why showing error message. Format your HDD and install OS to boot smoothly. But if you have HDD with OS still this error happening then it might be a reason of corrupt system files which are required during booting or it may be the case that your HDD is damaged and cannot boot from there. If your HDD is damaged and still showing on the BIOS it may happen because it is detecting as a device but the as the device is damaged is cannot boot from it. Check these steps to solve your issue.
    Jun 21, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
    Want to Boot from dvd ROM
    when the pc in post usually on dells bios there is a boot menu option it is usually f12
    if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
    Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
    CD ROM Boot
    In the BIOS are you able to "discover" the CD-ROM device? There should be a way such that you can specify what devices are connected to the system.
    The BIOS version should recognize what devices are attached to the system.
    You may need to "flash" (upgrade) the BIOS. Now a days, BIOS upgrades are available on the manufacturer's website.
    Hope this helps :) Kindly leave a rating. Thanks..
    Nov 27, 2007 | Acer TravelMate 2702WLMi Notebook
    Dell Latitude C640 Notebook Logo
    475 people viewed this question
    Ekse
    Clive
    Clive
