When i chooze a printer the printer which i have (cannonmx310)is not listed as a possibility
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Then it is not set up, need to re-install driver.
Use the cd or go to canon.com
drivers and downloads
Posted on Aug 25, 2008
Why not prinnting somtimes?
Go to the manufacturer's support section of their website to download the latest firmware update for that printer. Otherwise, the issue will probably be that different applications on your computer are set to (or default to) a different printer in the list (possibly to a PDF converter or some other file converter listed as a "printer" (for printing to files instead of printing to paper).
Dec 02, 2014 | Office Equipment & Supplies
I have a cannonmx310 all in one printer and lost my installation disc can i order another one
You can get the installation software online -->click here to download ..
Download / Installation Procedures
1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file.
Memo :
If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved.
2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ).
3. Double-click the downloaded EXE file to decompress it, then installation will start automatically .
Dec 11, 2010 | Canon PIXMA MX310 All-In-One Printer
I lost my cannonmx310 printer driver
Try the official canon link and post a query if there is any problem.
www.canon.driversdown.com
also check on :
www.driversbay.com/???drivers/printers/???canon/???pixma-ip1200/???microsoft-windows-2000
Sep 21, 2010 | Canon PIXMA MX310 All-In-One Printer
My computer is unable to detect this printer when I connect it. What could be the problem? The printer also does not turn off when I press the power button sometimes.
If the printer is not being detected correctly check both ends of the USB cable to ensure they are firmly attached. Do not have the cable connected to a USB hub or other device. If possible, try using an alternate USB cable that has been tested with another device and is known to work correctly. Ensure the USB cable is connected to a port on the BACK of the computer if possible as some ports on the front of the computer do not neccessarily supply the amount of power that is needed for printers.
Check the Device Manager listing to ensure the printer is showing up. To do this power the printer on and right click the My Computer icon on your computer then left click Properties. Select the Hardware tab and click the Device Manager button. Are there any listings displayed with a question mark or exclamation mark? Is USB Printing Support listed under the Universal Serial Bus Controllers section? You may need to click the plus sign beside this listing to expand the category tree.
If the printer is listed with an exclamation mark or question mark, right click the printer and click Remove, then select Action from the top of the window and select Scan For Hardware Changes. This should 'find' the printer again and the drivers should be reloaded successfully.
If the printer is listed correctly, try selecting the printer properties (browse to the printer window, right click the printer and select Printing Preferences) and clickc the Ports tab. Ensure the port that is selected is USBPRN01.
I hope this helps!
Feb 03, 2010 | HP PSC 1510 All-In-One InkJet Printer
I've just downloaded and installed the printer driver for my Samsung ML-2010 on my MacBook (OS X 10.5.6). The printer is working, when I do the test page, it prints fine. But when I ask it to print from...
Are you sure that it is your default printer if not try this :
1. From the print dialog, choose Edit Printer List from the Printer pop-up menu.
2. Select a printer from the Printer List.
3. Choose Make Default from the Printers menu.
In the Printer List window, a gray dot marks the default printer.
Then try again
Jan 04, 2010 | Samsung ML 2010 Laser Printer
My playstation 3 does not connect to my motorolla surfboard modem. i connect a ethernet cable from the back of my modem to the back of my ps3 and the ps3 says that there is no ethernet cable connected
hmmmm!!! lsn try to re-Setup the internet connection type all over again ok
main menu->setting->connection settings(internet option)-> here u have to set ur Internet connection up chooz the Wired connection then go with Easy and keep clicking on next till u test the internet connection okkk if it didnt work turn off ur modem for 5 mints ok
Dec 28, 2009 | Video Game Consoles & Games
Moved psc 1350 from old computer to my new computer. Missing installation disc and the director program did not install.
Please verify your equipment is in the Windows compatability list (search same for link). If listed or not, you will find instructions there. If not listed, visit HP at www.hp.com/suport for a driver. They may or may not support this device. You can always make a special request for support. If enough people demand it, they will support it if possible. There is the possibility of a 3rd party driver from ?
Alternatively, you can return your old computer to service and make it a print server with your printer attached on your network.
Thanks for your interest in FixYa.com
Dec 26, 2009 | HP PSC 1350 All-In-One Thermal Printer
I refilled my printer cartridges.they are full i did all the diagnostics cannon maitenance said and they are still not printing. it printed for a little bit then it stopped.it says that both of the...
You can't reset the ink level on all Canon Pixma printers.Press the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 02, 2009 | Canon Office Equipment & Supplies
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
jasbo
jasbo
