Question about Acer Aspire 3680 Laptop
My acer needs a new motherboard
Hello there , i just took my laptop to get fixed at a computer repair shop and was just told i need a new motherboard, is this somethin g i can fix my self or is there another cheaper route that i can go cause i cannot affoard the 450.00 repair cost... pls help....
You can do it yourself, but its not advisable, if you touch any other circuit boards that plus into it then they will break becuase of the static charge you have in your body. unless you know what you are doing, don't try it.
Posted on Aug 23, 2008
SOURCE:
I have an acer aspire 5552 series laptop, model pew76. It apparently needs a bio chip and a graphic chip according to my computer gugu - where might I find these?
Those chips are fairly inexpensive and yes you can get them easily here online and send them to her. However, these are not just snap on parts, they actually weld to the motherboard. With that, she will need someone with skill in doing this type of thing as it can easily go wrong. Now, keep in mind that if the laptop comes on but won't boot, the chip is fine, it's the bios programming that is shot. If the compter does not come on, it would be the bois chip. You can get the chip fairly cheep, but it is proprietary, meaning you have to get the exact model for your computer. Depending on what they would charge her wherever she is, for teh repair, it may be cheaper for her to send you the laptop as indipendant laptop repair shops here in the u.s. are fairly cheap. Good luck.
Sep 25, 2012 | Acer Aspire 5552 Laptop
My laptop has no signs of power. I was told a small chip on the mother board has burned out. Something to do with the power.
Sorry, but he's probably correct. You need to replace the whole motherboard.
You will never be able to find the chip to replace, let alone find someone qualified to correctly remove the bad chip and then replace it with a good one.
Jul 22, 2012 | Acer Aspire Computers & Internet
I took my Acer laptop in to be fixed. I had been wiggling my power cord for weeks in order to get a good power connection until finally no amout of wiggling would produce a good connection. The computer...
It's a very strong bet that your DC Power Jack (the hole the cord plugs into) has finally broken loose enough that it can't power the laptop. The jack is soldered to the motherboard. The repair shop probably does not have anyone skilled enough to desolder the jack and resolder a new one on. The part itself is only about $5 but you have to disassemble the laptop and remove the motherboard to properly repair it.
I send all such repairs for my customers to any one of several vendors on eBay who usually do the repair for around $50. I'm posting a link below of some choices for you. Pick a company with a high % Feedback rating and you should be just fine. You buy the Auction, send in the laptop and they usually guarantee your money back if they can't fix it.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1313&_nkw=Laptop+DC+Power+Jack+repair&_sacat=See-All-Categories
Regards,
Selk
Apr 08, 2011 | Acer Computers & Internet
My laptop is one month past the factory warranty and will not boot to windows..just goes to a blue hazy screen. I have ran the recovery, it went through the set up and booted to start screen and then...
Contact ACER and explain your problem and tell them the PC shop said it was probably the motherboard. Tell them it is just out of warranty and you expect help/repair for this so called quality product.
If you cannot get satisifaction, contact the government consumer affairs department in your country.
Sep 11, 2010 | Acer Aspire 6530-5143 Notebook PC
Pin from motherboard is broken. No more power
You'll need to replace the power jack.
Most shops / techs charge $75-100 but that depends on your location.
If you do itself it's about $10 for the jack.
You can get them on eBay fairly easy.
This type of repair is not covered under warranty.
Best of luck!
Jun 18, 2009 | Acer Aspire 5100 Notebook
Acer 5930 dead graphic card can it be fixed? or is it fixed to motherboard
Most laptops graphic cards are built right to motherboard. You can probably bring it to computer repair shop and they can solder new capacitors on it. But they don't make them seperate where a person could swap it out.
Jun 03, 2009 | Acer Aspire 5920-6574 Notebook
Charger pin broken off
daimese is poware battri
Dec 01, 2008 | Acer Aspire 3680 Laptop
I have a laptop manufactured by acer , model travelmate 3275 WXMi , suddenly stoped work , I took it to one of the computer maintenance shop , they told me there is a short circuit in the motherboard and...
wow.. that's as serious as it gets with laptops... depending how old your laptop is and if it's a few years old.. you may have to think about getting a new one as it may be as expensive (or more) to get the motherboard replacement plus the labor instead of just buying a new laptop.
at least you may still be able to get your data out of your the hard drive: get an hdd enclosure and use that hd as back up for your new laptop.
unfortanetely laptops are not as easy to work with as desktops when it comes to maintenance because most of their designs and physical technology included in them is propriatary so proper servicing it's tricky, more time consuming and therefore more expensive.
Oct 05, 2008 | Acer Computers & Internet
Acer laptop (aspire 5570z series) won't charge/turn on
I have the same piece a junk,the poor design of the power conector allows the barely soldered center pin to come out with the charging conector,mine lasted about a year,it was tight when it was new, have always been very careful with it and it still broke ,what a joke ,If you pull the pin out of the conector slightly then put it in slowly until you see the charge light go on in front of the computer,it wil charge
Jun 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3680 Laptop Logo
43 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
