Question about Fedders AEY08F2FCOM Wall/Window Air Conditioner
Maytag (Fedders) M6Y18F7A thru-the-wall unit.
The motor will start but usually does not. It hums loudly. It turns hard by hand. Probably needs lubrication. Is this possible on such a unit or are they sealed?
3 Suggested Answers
  • 6 Answers
SOURCE: I have a thru the wall fedders ac unit. The heat
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Posted on Apr 01, 2009
  • 659 Answers
SOURCE: heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
AC UNIT TRIPS THE BREAKER WHEN PLUGGED DIRECTLY TO WALL OUTLET AND FLIPS THE SURGE PROTECTOR TO OFF ALSO. WALL OUTLET WAS REPLACED AND STILL THE SAME ISSUE.
The problem might be in the compressor or fan motor. The compressor pulls a lot of amps, and much more if it's jammed or binding. The fan motor will do the same.
Aug 28, 2013 | Maytag M6Y18F7A Air Conditioner
I have a Maytag M6Q model window a/c unit. Diplay is in degrees Celsius. How do I switch back to Fahrenheit?
On most of these Maytag units, built by the now defunct, Fedders for Maytag ... if you press the ON/OFF button and hold it for 5 seconds, it should switch back to fahrenheit.
Hope this helped you.
Jun 10, 2011 | Maytag M6Q10F2D Thru-Wall/Window Air...
Dryer won't start. has power, lights are on, when I push start I just get a loud humming sound.
Try to turn the tub by hand, if it will not move or is real hard to turn, your motor may be locked down. They usually make a humming sound when you try to start.
Aug 28, 2010 | GE DPSB513BW Dryer
Unit turns on,compressor kicks on but fan does not turn,motor makes humming noise
sounds like fan motor has gone bad or the capacitor to fan motor is bad...open up unit ,see if motor is frozen..does it turn freely..if so ,replace capacitor,or fan motor is bad...
Jun 09, 2010 | Fedders AED24E7F Wall/Window Air...
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Ac motor hums and wont turn unless assisted manually
sounds like a bad capacitor its a little shiny can that is usually oval or round this gives it a kick start check the mfd rating (probably 3,4,5 mfd) and voltage (370 or 440) and replace the capacitor they are fairly inexspensive
Jul 29, 2009 | Fedders Appliance Air Conditioner Wall
Heat doesn't work on ac
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Fedders AEY08F2FCOM Wall/Window Air Conditioner Logo
53 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
