Question about HP PSC 750 All-In-One InkJet Printer
Scanner set up
When I scan the printer says options not set up, how do I do this? we have scanned in the past
    Master:
  • 623 Answers
Click start
right click properties
hardware
device manager
?ports
scan for hardware changes icon
Posted on Aug 23, 2008
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  1. Make sure that the product is connected to the computer.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
How do i scan?
Dallis,
1. Please power on the scanner.
2. Place the document to be scanned in the scanner face down and close the lid.
3. Start the word processor.
4. In the File menu you will find an option to either scann a document or Import from scanner. Use this and start the Scan Document.
5. First you will get a rough scanned image. Set it right for everything to be scanned by using a dotted rectangle on the scanned image. Once that is done, then use the SCAN option and you will get the final scanned image.
6. Save it to a folder.
Feb 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
hello there
first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
Thanks
Nov 13, 2010 | Brother MFC 7840W Printer
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
HP Officejet 6310x -when I try to scan it states "no scan option"
You don't have to re-install, just go to the HP Solution Center - Settings - Scan to Setup - and drag the applicatiosn you want the option to "Scan to", click on OK, and yer ready to go.
Feb 21, 2009 | HP Officejet 6310 All-In-One InkJet...
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Scanner
Are you getting a NO SCAN OPTION
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
If the software is not installed then you will have to install the printer driver and software sucessfully first.
Good Luck
Oct 12, 2008 | HP Officejet J5780 All-In-One InkJet...
Scanner
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 04, 2008 | HP OfficeJet 6310 All-in-One Printer...
No Scan Options for HP Oficejet 6310
This is a resolution for "NO SCAN OPTIONS" in the front panel screen of the All-In-One Only:
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 03, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP PSC 750 All-In-One InkJet Printer Logo
142 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
