Question about Acer Computers & Internet
Usb ports do not active
My laptop ,Acer travelmate 290E cannot support USB. When I plug in USB ,it shows "power surge on huport .A USB device has exceeded the power limits of its hubport .
    Problem Solver:
  • 7 Answers
One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
Posted on Aug 23, 2008
MY ACER TRAVELMATE 2350 DOES NOT ACCEPT USB DRIVES. THE USB DRIVES GETS POWER, BUT IT IS NOT SHOWN IN WINDOWS EXPLORER. ALL USB DRIVERS ARE PROPERLY GETS INSTALLED AND SHOWS IN DEVICE MANEGER. NEED...
NEED SOME SOLUTION.
THANKS IN ADVANCE
Jan 15, 2011 | Computers & Internet
When I plug a wireless cable into a USB port, the computer tells me that there are High speed USB ports available but does not inform where to find them.
Right-Click on My Computer, Properties, Device Manager, then Click on Universal Serial Bus Controllers, u will see the USB port available on your computer there. Also, at the same time you are doing this, try checking all the USB ports on your computer...most times, the HIGH-Speed USB Ports (USB 2.0) are always seperated from the other USB ports...so try the USB port seperated from others.
In your own case, Acer TravelMate 2303LCi has just 3 USB slots, a PC card slot, modem and network slot. No floppy drive, no TV-out, no IR, no Wi-Fi. So check-out USB Ports, the USB port infront of the Laptop beside the Audio Port and and the Speaker, on the extreme-right is your USB 2.0 High-Speed Port.
Jul 09, 2009 | Acer TravelMate 2303LCi Notebook
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Hi i have an acer laptop 5000 series the usb ports will not work saying power surge overloaded,would buying a usb card solve the problem.Any help would be much appreciated.
are you using windows xp sp2, this issue normally occurs with it
a fast fix is:
go to start menu> run > type in devmgmt.msc > ok
1) Device Manager will open
2) Locate "Universal Serial Bus controllers" in the list and expand
3) Select the first USB Universal Host Controller.
4) Right click and select "Properties"
5) Go to the "Advanced" tab
6) Check "Don't tell me about USB errors"
7) Click "OK"
Note. If you have multiple host controllers then they should all be affected by the above action.
8) Close Device Manager
further Queries are welcome
Feb 18, 2009 | Acer TravelMate 4100 Notebook
Power surge on usb port
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
Jul 12, 2008 | Computers & Internet
LAPTOP ACER TRAVELMATE NO USB PORTS WORKING
clarification request:
check the plug and play if working properly also check the usb port maybe lose usb port
May 27, 2008 | Acer TravelMate 2300 Notebook
Acer Travelmate 3200 usb dont work
this may help - or not..
http://support.microsoft.com/?kbid=310575
If you have damaged the USB chip on the motherboard, you may be able to disable it in the BIOS. Then when you install your PCMCIA card it may work...
USB is not as tolerant of short circuits as RS232. I know I managed to destroy one of the ports on my m/b.! Using a Hoover may not be a good idea.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
USB problem
no there must be some problem with your usb port.......
Feb 26, 2008 | Acer TravelMate 2303LCi Notebook
Usb ports
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
260 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
