Question about Goodman CKL60AR60 Air Conditioner
Compressor problem I have a 3ton goodman unit about a month ago my unit started blowing hot air found out compressor wasn't running turned unit off technician came out turn unit on got pressure readings found low charge added refrigerant the unit did well, then the problem started again i called a company out to look @ it and from what I can see he didn't have alot of experience he stayed on the phone with his boss to walk him through the situation (remember compressor is not running) he runs water on compressor to cool it down then checked pressures found i didn't need refrigerant so he goes in my attic comes down to say i had water in my pan removed the water then he tells me my evap. is dirty and that was my problem he needed to pull it out take it out wash it then put it back now i dont think that a dirty evap. will stop a compressor from coming on it trys to start but it kicks out in exactly one second what could possibly be my problem bad comp or low charge. PLEASE HELP!!!!
  • Anonymous Aug 23, 2008
    even if the fan still comes on
  • 182 Answers
Sounds to me like the capacitor is no good.
Posted on Aug 23, 2008
SOURCE:
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Outside unit will not come on
Check the starter capacitor, and di you remember to add oil?
Aug 27, 2009 | Goodman CLQ36AR49 Air Conditioner
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Jun 11, 2009 | Goodman CKL60AR60 Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Another Goodman compressor
Maybe,maybe not.Disconnect the power to the unit.Have a tech check the capacitor.
Jun 26, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
99 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
