Wont boot to windows,say to check a cable - Computers & Internet
  • 32 Answers
What exactly does it say? What cable is it saying to check? I need the operating system and type of computer as well.
Posted on Aug 23, 2008
Computer wont boot up
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Feb 26, 2013 | Toshiba Satellite C850D-BT2N11...
I have a 2000 Toyota Land Cruirser Prado 3400 V6 Windows wont work . Checked Fuse under dash board is ok . Any sugestions?
check the cables in the rubber boot from the door into the door pilar drivers side as they often break a cable in this area ,well all cars in fact and the big multiplug as well
Mar 03, 2012 | Toyota Land Cruiser Cars & Trucks
My computer wont boot up it keeps bleeping
Its RAM problem. Check your RAM, also check your cables. To optomize your PC use system utility software like RegInOut to fix corrupt registry & windows files, it will also speedup your PC.
Dec 23, 2011 | HP Pavilion Computers & Internet
Sony vaio vgn-fj270 bios wont boot, just display [Be-$]Be-$
try to turn off the laptop. Remove cables and battery then press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn on the laptop. Check if the BIOS screen appears. If it is still wont boot to windows, try to restart the pc and repeatedly press F8 to Boot to safe mode. If unsuccessful, this might be a problem with the memory of your laptop. If you cannot tear down the laptop, consult a technician to tear it down and reseat the memory .. or better call your manufacturer to repair it...
Jan 05, 2011 | Sony VAIO VGN-FJ270/B Notebook
Screen wont turn on with pc
check to see that your monitor cable is plugged in correctly and firmly.
If not boot into safe mode of windows and change your screen resolution to something compatible with your monitor.
try this and tell me what`s up.
Mar 22, 2009 | ASUS A7V600-X Motherboard
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Cannot boot into windows.
Try putting the jumper on your drive to CS (cable select) and make sure your hard drive is located at the end of the ribbon cable. This is assuming you are using a 80-conductor cable and not 40. If you happen to be using a 40-conductor cable (unlikely) make sure its on the middle of the ribbon cable. See if this works.
Jan 20, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
Windows won't start
reassemble and check for all
Nov 06, 2007 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
