Question about Radio Communications
Regency Touch K500
Can you tell me where I can download a manual for my scanner?
    Scholar:
  • 66 Answers
Yes, go to http://www.radiopics.com/1.%20Manuals/Regency/Regency_Touch%20K500%20(Manual).pdf
You can download the pdf format from that website, however you must have Adobe Acrobat Reader.
Hope this Helps!
Posted on Sep 07, 2008
SOURCE:
I have an Old Regency Toutch K 100 20 CH S1&S2 S1 is 1-10 CH ?? S2 Ch 11-20 is that correct?? or do you also use CH 1- 10 on S2 ??? What is a Code '' d '' It will not scan all 20 Ch only S2, and not...
The K100 is an oldie from about 1980, when Regency was still manufacturing some radios in the USA and importing some from Japan. Below is a link to the manual for the K500, which had more channels & features than the 100, but was a similar radio. There is currently an eBay listing for the K100 manual (pdf) if you want to spend a few bucks.
http://www.repeater-builder.com/relm-regency-wilson/regency-touch-k500.pdf
Nov 21, 2009 | Radio Shack Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
FINDING FREQUENCIES
87ff97c.jpgNo it can't sorry. If you want to scan things all the way up to the 900 MHz frequency you should get a Regency Touch K500. Its not a portable scanner however. It may be a little hard to find because Regency went out of business a while back, but look on e-Bay you'll find it there.
Jun 28, 2008 | Uniden BC72XLT Handheld Scanner
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Icom IC-R33
Most scanners do not have the capability to scan 900 MHz channels, but the Regency Touch K500 can. And no you can't digitize a scanner that hasn't been built to be digital trunking. As for your other question, I don't understand about the VHSC thing.
Jun 22, 2008 | Radio Communications
Uniden sc230 scanner
The lock out function is a common problem in scanners, to override the lockout command, you can press and hold the lock out button, or punch in the frequency that you locked out and unlock it by pressing the appropriate buttons depending on the model of your scanner. Here is a suggestion, for easy scanning I recommend a Regency Touch K500 Scanner. It may be hard to find one though, Regency went out of business a while back, but I had the K500 and it was the best scanner I ever had.
Mar 22, 2008 | Uniden BC72XLT Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
383 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
