Source selector problem, for eg if the selector is on cd and i plug a cd player in the tuner input, i can hear the sound. no matter what source the selector button is on.
Hi Seamus377
You have a faulty input selector chip by the sound of it. First, power the amp off at the wall for 30 mins, then fire it up again to see if that resets the problem.
Hopefully that fixed the problem, if not, you may need to get a tech to look at it. The input selector chips are quite sensitive and susceptible to failure, producing the symptoms you speak of. They can be damaged also and fail at any point if subjected to a voltage spike. Here is why they fail
When outboard devices such as
are plugged into your amp, the RCA connectors connect the center "signal" connection first, then the earth ring. Until the earth ring connects, any potential difference or stray voltage present on the earth of the connection being plugged in, can result in as much as 50volts being spiked into the input selector chip. I have seen scores of amps damaged by this.
How to avoid it
Before making any connections to your amp, FIRST
Good luck, hope you get it sorted out. I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
denon pma-355uk amplifier
