Try to delete and add again the music files you have in your memory card. Then create a new playlist.
To create a playlist:
1. In Menu mode, select Music player ? Playlists.
2. Press ? Create playlist.
3. Enter a title for your new playlist and press
4. Select the new playlist.
5. Press ? Add ? Tracks.
6. Select the files you want to include and press
To customise your music player settings
Learn to adjust the playback and sound settings for
your music player.
1. In Menu mode, select Music player.
2. Press ? Player settings.
3. Adjust the settings to customise your music
player.
4. Press .
It is possible that the phone has errors in the memory card. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card.Copy good music files from you PC. Now replace the card and battery and switch on the phone. If the phone does not detected then it is possible that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Thank You for using Fixya
im sorry about that!!
i went to
http://nds1.nokia.com/phones/files/guides/Nokia_3110_classic_UG_en.pdf
Your device includes a music player for listening to music tracks or other MP3 or AAC sound files that you have downloaded from
the web or transferred to the device with Nokia PC Suite. See "Nokia PC Suite," p. 40.
Music files stored in the music folder in the device memory or on the memory card are automatically detected and added to the
music library during the startup of the device.
To open the music player, select Menu > Media > Music player.
to manage the songs and stuff like that:
Copyright protections may prevent some images, music (including ringing tones), and other content from being copied,
modified, transferred or forwarded.
Manage images, video clips, music files, themes, graphics, tones, recordings, and received files. These files are stored in the
device memory or an attached memory card and may be arranged in folders.
Your device supports an activation key system to protect acquired content. Always check the delivery terms of any content and
activation key before acquiring them, as they may be subject to a fee.
Folders and files
To see the list of folders, select Menu > Gallery.
To view the list of files in a folder, select a folder and Open.
To see the available options of a folder or a file, select a folder or a file and Options.
To view the folders of the memory card when moving a file, scroll to the memory card, and press the scroll key right.
****IF ITS MISSING ALL TOGETHER:
To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett.. Enter the security
code.
The names and phone numbers saved in Contacts are not deleted.
I hope this helps!!!!
