Question about Nikon Coolpix 3200 Digital Camera
Problem installing Nikon View - "Locale does not match" error
When I try to install Nikon View/Nikon Capture updater I get an error: "The locale for the installed Nikon View software does not match. Cancelling Installation" What does this mean?
    Novelist:
    Scholar:
  • 79 Answers
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page. http://www.nikonusa.com/software Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Posted on Aug 30, 2005
Unable to install hulu plus app because error 52230 keeps appearing need to know how to install
Try this site below it will help you as it is a part of the official Nintendo website not to many people think to go here.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52230&system=Wii&locale=en_US
Jan 12, 2013 | Nintendo Wii Fit - Balance Board + Game...
Vista 32 bit Operating system is in Turkish.But I want int .Exp.8 in English ..please help
You can try changing the locale. This is in Control Panel->Region and Language->Administrative->Change System Locale. You can also install/uninstall languages from the language tab.
Hope this helps
Ray
Mar 03, 2011 | Computers & Internet
Can not run Nikon Capture 3 - "Updated Driver Required"
Under some limited conditions, Nikon Capture 3 will fail to launch after the initial installation and you will not be presented with the opening dialog which allows you to select either "Trial" mode or be permitted to enter your serial key. A dialog box is displayed indicating that updated drivers are required, but the names of these drivers are not listed. This installer replaces two files with updated versions which resolves this issue and allows Nikon Capture 3 to launch. Do not install this update if you are already running Nikon Capture in trial or registered mode. This update is not required for any version of Nikon Capture other than 3.0. This updater is not needed for Macintosh users. After downloading and decompressing, double click the "Setup" application to install. http://www.nikonusa.com/software/Cap3update.zip
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
D100 Driver Update
What is this? This is an updater to the D100 driver module. This is needed for users who have Nikon Scan 3.1.2 and Nikon Capture 3.0 installed regardless of whether or not a Nikon D100 is used. This updater will fix an error relating to a "D100.md3" file. This update is not needed for Macintosh users. What’s new? The following issue has been addressed: This update fixes an issue that causes Nikon Scan to unexpectedly quit during software startup. All users of Nikon Scan and Nikon Capture should install this update. Compatible OS: Microsoft Windows 98 Second Edition Microsoft Windows Me Microsoft Windows 2000 Professional Microsoft Windows XP Professional Microsoft Windows XP Home Edition *All pre-installed models only What’s included in the download? “D100_driver.zip” Special notes: Installation: When the file, “D100_driver.zip” is downloaded, it should be automatically decoded to create the installer “D100UPDATER_E.EXE”. Run this application to install the upgrade. http://www.nikonusa.com/software/D100_driver.zip
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
"Nikon software does not run on this Operating System" Error Message
When attempting to install Nikon Capture or PictureProject on certain Windows 98SE systems the following error messages may present themselves: This message is caused by the registry key value for the "SubVersionNumber" on the version of Windows. If the system contains SubVersionNumber "B" Nikon Capture and PictureProject will not install on the system. Below are instructions on how to manually edit the System Registry to change the SubVersionNumber Registry Key to allow for Nikon Capture and Picture Project to install. Manually editing the System Registry requires vigilance and care because a mistake could cause errors with the System. Be extremely careful when editing these keys. Nikon is not responsible for any loss due to problems with registry key editing. To manually edit the System’s Registry: 1) Quit all running applications 2) Click on "Start" then "Run…" Type the following in the run command line: "regedit" 3) Click "OK" and the registry editor will open 4) Click "Edit" from the menu bar and choose "Find" 5) Type "4.10.2222" into the "Find What:" field 6) Click "Find Next" The results will appear in the column on the right. The Version Number will be highlighted. 7) Click on "SubVersionNumber" once. 8) Go to "Edit" on the menu bar and choose "Modify" 9) The current Value data will read B. 10) Change "Value data" to " A" (MAKE SURE THERE IS A SPACE BEFORE THE A) 11) Go to "Registry" in the menu bar and choose "Exit" 12) Confirm the change has taken effect. Right-click on "My Computer", choose "Properties". 13) The version value should reflect "4.10.2222 A" Nikon Capture and Picture Project can now be installed and run on this system.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Capture 3 and Mac OS X 10.2 Installer Issue
On Friday August 23, 2002 Apple released an updated version (Mac OS 10.2) to the Mac operating system. While we are NOT yet announcing compatibility information we do have the following information regarding one issue. Mac OS X has a built-in feature that scans items as they are installed to check for security issues. When Nikon Capture 3.0 is installed the dialog box below will display indicating a possible issue. If the user clicks "Fix and Use" the dialog will be dismissed and the application will run as expected. If the "Use" button is clicked the application will run fine untilthe Mac has been restarted at which time the same dialog will appear. If "Don't Use" is clicked Capture 3 can not be started. A future version of the Nikon Capture installer will prevent this. As compatibility and usage information is available I will update you on Nikon software and OS compatibility.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Under some limited conditions, Nikon Capture 3 will fail to launch after the initial installation and you will not be presented with the opening dialog which allows you to select either "Trial" mode or be permitted to enter your serial key. A dialog box is displayed indicating that updated drivers are required, but the names of these drivers are not listed. This installer replaces two files with updated versions which resolves this issue and allows Nikon Capture 3 to launch. Do not install this update if you are already running Nikon Capture in trial or registered mode. This update is not required for any version of Nikon Capture other than 3.0. This updater is not needed for Macintosh users. After downloading and decompressing, double click the "Setup" application to install. Click here to agree to license and Download the Capture 3 Installer Update http://www.nikonusa.com/software/Cap3update.zip
D100 Driver Update
What is this? This is an updater to the D100 driver module. This is needed for users who have Nikon Scan 3.1.2 and Nikon Capture 3.0 installed regardless of whether or not a Nikon D100 is used. This updater will fix an error relating to a "D100.md3" file. This update is not needed for Macintosh users. What’s new? The following issue has been addressed: This update fixes an issue that causes Nikon Scan to unexpectedly quit during software startup. All users of Nikon Scan and Nikon Capture should install this update. Compatible OS: Microsoft Windows 98 Second Edition Microsoft Windows Me Microsoft Windows 2000 Professional Microsoft Windows XP Professional Microsoft Windows XP Home Edition *All pre-installed models only What’s included in the download? “D100_driver.zip” Special notes: Installation: When the file, “D100_driver.zip” is downloaded, it should be automatically decoded to create the installer “D100UPDATER_E.EXE”. Run this application to install the upgrade. http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=183&p_created=1029875958&p_sid=-u9YedOh&p_lva=7128&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzcmcF9wcm9kcz0xLDImcF9jYXRzPTE4NCZwX3B2PTIuMiZwX2N2PTEuMTg0OzIudTAmcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Nikon Coolpix 3200 Digital Camera Logo
103 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
