We are having the same problem. The washer smell like mold when you open the door. It also makes the clothes smell like mold. I did run the washer with bleach but the problem comes back. Did you solve the problem with your washer.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath.The panel will drop and come off.Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub.This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water.After it starts agitating stop the washer & let it remain for 2 hours.Then continue the wash.
Was this helpful?
Yes
No
Popular Solutions for Bosch WFMC2100UC WFMC 2100 UC
There is water leaking from the front of my Bosch Nexxt Essence washer. It is not coming from the...
(More)
There is water leaking from the front of my Bosch Nexxt Essence washer. It is not coming from the back just the front edge?
It rarely get's past 52 minute point (Regular/Cotton cycle), simply stops and even though the door...
(More)
It rarely get's past 52 minute point (Regular/Cotton cycle), simply stops and even though the door locked indicator is still lit, the door can still be easily opened. It begins pumping water out in the first minute even after the repairman replaced the pressure switch. At first the repairman thought it was acting up because we were using too much detergent even though we were going by what the manual recommends. The repairman said Bosch is rewriting it's manuals recommending only a teaspon of detergent for this and other front load washing machines. We've tried the running cascade dish detergent through it trick to no avail, as well. Before all of this it was running fine with the exception that sometimes we'd have to run it on the handwash drain and spin cycles again because the clothes were still very wet at the end of the cycle. Again, repairman attributed this to too much soap. We also unscrewed the drain access cap that's 5 o'clock to the washer door and it seemed pretty clean. The repairman is quite confounded by it to the point where he said he'd be willing to find someone else to work on it. That's all I can think of. Any suggestions would be mighty appreciated.
