Question about Kenmore Elite HE4 Electric Dryer
Kenmore Model # 110.85862400
We have had the control panel replace 2 times in 2 years. Whats the problem? It lit up but wouldn't do anything.
    Scholar:
  • 121 Answers
Hi! dottippett
Do you live in a high humidity area, if so the terminals may need to be cleaned on all the Integrated Circuit (IC) cards. There are three IC's, and thus several sets of interconnecting cables. Unplug the unit, after removing the rear panel check the voltage at the power terminals where the power cord is connected. Clean the contacts with a soft eraser to polish the contacts. After cleaning coat the contacts with non-conductive contact grease. Several other people are having similar problems.
Posted on Aug 28, 2008
Kenmore HE2 Plus Model# 11047512600 When pushing the start button it will just beep 3 times and not do anything, door won't lock or start cycle. No error codes are displayed. Whats wrong?
Hello Jason,
Regarding
  • There is a communication error in the control board.
  • Also the door Latch assembly may be defective. Check & replace as necessary.
Here is a link to Sears parts direct.
KENMORE RESIDENTIAL WASHER Parts Model 11047512600 Sears PartsDirect
Jun 25, 2015 | Kenmore Washing Machines
Kenmore microwave hood combination
If you have tried to reset the microwave oven by turning the mains power off and on without success then it is likely the display is faulty.
The only way to repair is replace the control panel board. This can cost a lot of money.
See this site to give you some idea. Best to contact a repair technician and get an idea of costs.
KENMORE ELITE Microwave Range Hood Controller Parts Model 72180839500
Aug 03, 2014 | Kenmore 1.4 cu. ft. Speedcook Microwave...
Kenmore washer model - 41744042400, will not cycle through. It stays on the same setting the whole time. Whats the problem and how do I fix it?
Possible fault with the main program controller unit, needs a replacement if the wiring and the controller panel is seen to be in order.
Oct 09, 2012 | Kenmore Washing Machines
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My Kenmore side-by-side refrigerator keeps
you have a bad control board. if its less than a year old it should be under warranty still. if its over a year the board is fairly easy to replace yourself. you can look up the part at partsdirect.com and if you'll give me a complete model number I'll give you step by step instructions for replacing it. thanks peyton
Mar 10, 2009 | Kenmore 53352 / 53354 / 53359 Side by Side...
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
Model 721.80803400 microwave blank control panel
there is a transformer on front pc board.might need tech to have a looksee
Aug 28, 2006 | Kenmore 80809 Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Kenmore Elite HE4 Electric Dryer Logo
264 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
