Question about E-Machines eMachines Desktop PC
EMachines PC that has not yet been thrown out the window, but....
I have tried another monitor - same story. My problem started with a power blink. The computer shut down and then rebooted, but the only thing we got was the Windows XP landscape with the emachines logo. I can't get to my BIOS - tried F1, F2, Del, F8. I have tried the recovery discs and I have tried my Windows XP Professional (this computer has XP Home, but did not come with disc).
Then we started with the monitor issue that you have already read about.
What do you think my problem is?
    Scholar:
  • 152 Answers
If this computer came with XP Home, and you don't have a disc, then they would have put the restore files in a separate partition on the hard drive. Do you have the manual for the pc? It's possible to recover your system without losing everything. What happened when you used the recovery disks and XP Pro?
Posted on Aug 23, 2008
Emachine T2240 computer, powers on no signal on monitor. Power goes on, but no video?
When power supply got burned on the computer. A problem arises first in the CPU. If the power supply burned because of a power glits is a different story. try to save your data you probably need to buy a new computer.
Nov 04, 2015 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
My modem blinks off and on , when my pc is idle. Is that normal? and where could I buy a book on info on e-machines? When my monitor goes dark, then my modem starts blinking off and on. My computer is...
your modem is always talking to your service even when not connected to your pc it is just showing that it is working. Emachine manuals are a little hard to find, your best bet is to contact the store where you bought it, I know Best Buy used to sell the, they may have a manual, and you could try contacting emachines directly.
Mar 12, 2011 | Acer eMachines Black EL1850G-42w Desktop...
Blank sreen.Fan is working. LED indicator is lighted but blinking rapidly.
Try a different monitor. If the second monitor doesn't work disconnect the power and then re-seat the video card. Also, check the RAMs - make sure they're seated as well. Start-up the computer and verify that the hard drive LED is blinking randomly - if it is, more than likely the computer is working properly. Your monitor could be bad as well as the video card. If the VGA port is on the motherboard, then you have an on board graphics card instead of a video card. In that case, the motherboard is bad.
Nov 19, 2010 | E-Machines eMachines Desktop PC
Replaced Mainboard on Emachine w3653, keeps restarting
If it reboots before you make the Windows load screen, chances are it's the power supply. You can go into the BIOS, look at the power setup and with most BIOS's you can watch the DC supplies. If they vary like mad while you're doing this (with the PC effectively in idle), either something is loading down the power supply or it's defective.
If it gets to the Windows startup screen and starts to load, then reboots, it's probably a defective RAM chip.
Sep 01, 2009 | E-Machines eMachines Desktop PC
Change monitor display from landscape to portrait
Try pressing CTRL ALT and the UP ARROW keys together.
Jan 02, 2009 | E-Machines eMachines Desktop PC
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
133 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
