To turn off your child lock on sanyo tv: 1. Press the "Menu" button from the remote 2. Then press the "CH+/-" twice 3. Press the "Enter" button to access the submenu 4. Enter the password. The default password is "1234", but if you already changed the password make sure to enter it correctly 5. Press "Enter" to switch off the child lock. Do the same if you want to switch it on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I just purchaced an RCA best model universal remote for $15.
That should be a solultion. It has a complete list of codes for many popular devices. Instructions are clear.
Or MFG customer service email may help you with a replacement.
Hi good day. My sanyo lcd 32K30 was locked and i dont know how to unlock it because i dont have a remote control. Would you please help me to fix it? Thanks
my sanyo lcd 32k30 have a problem when i turn on half on the screen the picture is ok and the half is black after a few seconds the picture is full what is the problem? can you help me of this trouble of my sanyo lcd 32k30 thank you
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as
they contain potentially lethal voltages that must be properly
discharged before work can begin.
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
