Question about Maxent MX-26X3 Television
Maxent 26" lcd tv, shorted circuit board
I have shorted power circuit board and I can not find a replacment, can you tell me how to find the shorted part? Any help would be appreicated.
  • Tim Adams Jan 24, 2009
    I am not sure if mine is the circut board or not. I moved the tv and when I plugged it in sparks came from the back. I believe they came from the toggle switch area. Looking online for thoughts and ideas before I take it apart.
The best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
Posted on Mar 18, 2009
SOURCE:
Maxent tv Use the remote to turn on tv, most times the tv will come on in about 30 min.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 15, 2017 | Maxent Televison & Video
My maxent TV comes on, with no picture, just a whining noise??
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 21, 2016 | Maxent Televison & Video
Maxent 94202yd05 T.V.. Sound but no picture
Oct 21, 2016 | Maxent Televison & Video
What the problem when tv want power on
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 20, 2015 | Videosecu TV Ceiling Mount for Vizio 23 24...
Lg tv is stuck in a standby mode
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 14, 2015 | LG 26 26LV2500 26 LCD TV
Due to electric power problem my 26" samsung LCD TV blown up. Is there any safety measure in the form of fuse or circuit breaker in LCD TV's manufactured by Samsung India
Yes. The TV has a solder in 4.5 amp fuse. BUT most of the time when the power surges it also shorts the Bridge rectifier assy. IF you are not familiar with solder techniques, you will have to replace the power supply board. SHOP jimmy has in stock. Use model number .
Feb 18, 2011 | Samsung LA26A450 26 in. LCD TV
I plugged in my sanyo 26" lcd tv and there's a thick white vertical line down the center of the tv. I don't know what to do about it.
If the unit is under warranty, return it to the manufacturer for a replacement or a refund.
What you need t check is that the voltages from the printed circuit boards to the LCD panel are giving the correct voltages, also check the logic printed circuit board for shorted components or incorrect voltage values, if after checking the voltages frim each printed circuit board, everything is testing ok, the problem may be that you need a replacement LCD panel. But make sure to throughly check the main printed circuit board for any faulty solder jouints , or dry joints, as well as any blown or shorted components. I hope this helps. Good luck.
Jun 20, 2010 | Sanyo DP26648-R 26 in. LCD TV
No power to tv
U check ur power source with other electronic devices?Yes than ur power supply board is dead.Replaced the power supply board will fix the power problems.Tries Website like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 02, 2010 | Maxent MX-32X3 32 in. HD-Ready LCD...
Hey got a good one for ya....The TV had fallen and there is a corner on the plastic cabinet that is broken away.When plugged in and turned on the blue power on indicator will light up and you can hear a...
LCD sets sometimes will not power up until the backlight boards power up. the backlight boards have SMT fuses that open. and driver FETs (commonly also SMT) that short.
check the backlight circuits first.
Dec 05, 2008 | JVC LT-26WX84 26 in. LCD HDTV
Televison & Video Logo
570 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
