Question about Electrolux Epic 6500 Vacuum
Replace vacuum motor on a Electrolux Epic 6500 sr
Not sure if I attached the wiring correct. The replacement motor works if I plug directly to power. However, if I attached to the wires on the vacuum will not start. There are three wires two blacks and one white. The replacement motor only has two wires. I try several different ways but the motor will not start.
Thanks
Raul
  • methodistbil Sep 10, 2008
    I have a similar problem. I had to replace the elbow on the power nozzle and don't know how to get all the wires reattached to the motor and circuit breaker.
  • j600r Oct 20, 2008
    I found a motor for my Electorlux Epic 6500 but do not have instructions as to how to replace it. Is this something I can do with common household tools? Where can I find directions?
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
SOURCE: cord won't rewind. How do I take apart to repair?
see jan 1, 2009
Posted on Apr 19, 2009
  • 430 Answers
SOURCE: What size/model bags do I need for my Electrolux
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Posted on Sep 08, 2009
SOURCE: electrolux vacuum epic 6500 sr shows a lighted
clean filters and ducts
Posted on Dec 13, 2009
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
Need a new aerus motor for epic series 6500 SR
ebay is the most reasonable place to purchase one $34-$50 dollars
Jul 18, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Nov 20, 2008 | Electrolux Epic 6500 Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
233 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
