Question about Toshiba Computers & Internet
Power up failed
My satellite P10-304 wont power up when i push the power button.. there power coming from the power supply but it wont power up.. what could be the problem and how do i fix this?? please help.. thank you very much!!!
Maybe you could try getting a new cord. or a new battery.
Posted on Aug 23, 2008
Snx 32gt1 internet tv wont come on
Probably a failing power supply
Jan 14, 2017 | Sony Televison & Video
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
Wont turn on
What power supply are you using? You need the older 6volt unit. Next, look down inside where you plug the power plug in. Many times the tip of the plug will break off and get stuck down inside the hole - if you see a piece of yellow plastic down there, you need to remove it with a small pointed hobby knife (Xacto). After you remove that, then try plugging the power supply in and wait a minute. IF it doesn't automatically come on, THEN push the power button. Okay?
Aug 14, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
POWER WONT COME ON
HI, this is a failed power supply board. replacing this failed component will fix this issue. Replace the power supply board.
Jun 11, 2009 | Microsoft Xbox 360 Console
My computer wont turn on
Remove the power cable and hold down the power button for about 30 to 60 seconds. plug the power back in and see what happens. If fail look at the back of your computer ans make sure that the fan for the power supply is on. Also make sure that the red switch is set to 115V and not 220V. This is also located in the power supply.
If al has failed your power supply is no longer working and will need to be replaced.
Apr 22, 2009 | E-Machines eMachines Desktop PC
Sound like 'classic' failing capacitor symptoms to me... RMA the power supply if you're able to, start scraping together some cash for either a rebuild (replace capacitors) if you can't OR purchase a NEW PSU
Once you get the system running... I would recommend you leave it turned on 24/7 as this will keep the failing capacitors at a static temperature (instead of the heating/cooling cycle) thus milking the last bit off life out of it while you secure a replacement unit.
Jan 15, 2009 | Cooler Master (RS-380PMSR/P) (RS380PMSRP)...
Satellite 2430 wont boot. when the start button is pushed nothing happens
Dear Customer,
1.if no sound
2.no led indicator lights up
than definatly its a power supply problem check your SMPS at top back side of your cabinet .
disconnected SMPS than ckeck its power supply at different ports.
THNX
May 17, 2008 | Toshiba Computers & Internet
Tv just wont turn on
power supply fault it could be any component if not qualified dont risk taking a look inside, high voltage supply.
Oct 14, 2007 | Panasonic (LSSQ0372) Remote Control
Computers & Internet Logo
228 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
