Question about kawasaki Blue 3.5'' Kids' Portable DVD Player - PVS133B-B
Will not load DVD
The dvd says that it is loading but once it finishes it says no valid disc
  • 3 Answers
1) If the DVD is a burned disc, instead of a factory-pressed original, try different media types and brands.
2) Also check that the disc is unscratched and otherwise clean. Inspect the laser lens and make sure that it is clean as well.
3) Make sure that the disc is truly a DVD or audio CD, and not a VCD or DivX movie on CD.
Posted on Aug 31, 2008
6ya staff
SOURCE:
No Disc when loaded
The player is not a able to read that DVD format, or the DVD is a defect:
Jan 11, 2013 | Sylvania SDVD7002B 7 Portable Dvd Player...
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
My Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Jun 07, 2010 | Televison & Video
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Suddenly quit working
Looks like the lens of the player is dirty or damaged. Try a lens cleaner CD first.
http://www.buy.com/prod/maxell-cd-340-cd-lens-cleaner-lens-cleaner/q/loc/111/90049765.html
If it doesn't work then you will have to get the lens replaced. Since the Player is still under warranty use while you still can..
Jun 17, 2008 | Mintek MDP-1770 Portable DVD Player
DVD load problem
run a lens cleaner thru it to clean the lens. use the NON liquid type ... its a disc with little brushes on it you can get from radio shack for a few bucks.
May 26, 2008 | Emerson EWD2203 DVD Player/VCR
No valid disc
Hi, Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional. Good luck and kind regards.
Sep 28, 2007 | TruTech PVS12701 Portable DVD Player
Televison & Video Logo
99 people viewed this question
Top kawasaki Televison & Video Experts
Damen Wong
Damen Wong
Jaime Hernandez
Ekse
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
