Question about HP Pavilion dv1000 Notebook
Administrator Password for BIOS lost
I am not able to change my boot options sice i have lost my administration password .. can i do it without any mechanical works on the laptop....iam using " HP nx6110 " pls help me up soon............... I am using a hp510 laptop and have lost my administrator password aswel need help please email me jamesisolda@googlemail.com
  • 50 Answers
To fix the problem is simple. I did it just last week and it worked fine. Go to the control panel and call up Users. Add a new user called 'Administrator' (no apostrophies) and sure enough you have an administrator once again. I just took a shot in the dark and it worked fine.
Posted on Sep 15, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Hi jamessisolda
I think the others will agree with me taht there is one way and oneway only and taht is to take out the battery and leave the laptop for a couple of days for the internal cmos battery to run down.
I think thats the only way.
Posted on Sep 10, 2008
Clear cmos
if you want to reset your password or your cmos
When you boot up to the log in screen type in administrator as user to log in if you cant log in
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps you
start a windows xp system up n safe mode then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one. Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
Close the User Accounts window and restart Windows.
hope this helps you
Sep 29, 2011 | Intel D946GZTS Motherboard
Tip
Three Tips for Windows XP Administrator Password Recovery
Unlike Windows 7 and Vista, the default administrator account on Windows XP is enabled and not password protected. And by this unique feature, you can easily reset a forgotten login password to Windows XP when you are locked out of computer. But if you added a password to this built-in administrator account before and now cannot remember its password, what will you do to reset this forgotten Windows XP default administrator password? Here's some advice on <a href="http://www.anypasswordrecovery.com/windows-xp-administrator-password-recovery.html">Windows XP administrator password</a> recovery for you if your Windows XP machine is in use.<br /><br />Tip 1: Take advantage of password recovery disk<br /><br />Provided a password reset disk for the default administrator account is created in advance, Windows XP administrator password recovery can be completed within a few clicks.<br /><br /><img src="yaoch_1.png" /><br /><br />Step 1. Go to Windows XP logon screen and enter a wrong password for the administrator account.<br /><br />Step 2. Press Enter to pop up the "logon failed" dialog box, and click "use your password reset disk".<br /><br />Step 3. On the Password Reset Wizard screen, click Next to change this administrator password.<br /><br />Tip 2: Try Windows Password Recovery Software<br /><br />If you forgot Windows administrator password without a password reset disk, don't feel impressed. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> can solve your problem. It allows you to create a password reset CD/DVD to reset lost Windows XP administrator password.<br /><br /><img src="yaoch_2.png" /><br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable password reset CD/DVD.<br /><br />Step 3. Boot your locked computer form the CD/DVD.<br /><br />Step 4. <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html">Reset Windows XP password</a> under Win PE.<br /><br />Step 5. Log on computer via this administrator account without password.<br /><br />Note: With intuitive GUI, you can defeat Windows XP administrator password within a few clicks, regardless of your level of computer knowledge. 100% recovery rate guaranteed.<br /><br />Tip 3: Use a user account with administrator permission<br /><br />It is well-known that users can create 2 kinds of administrator account on Window XP. One is a user account with administrator privileges while the other is the built-in administrator account. So when you forgot Windows XP default administrator password, you can log on computer with another kind of administrator account and then do as follows:<br /><br /><img src="yaoch_3.png" /><br /><br />Step 1. Right-click My Computer icon to select Mange.<br /><br />Step 2. On the coming up classic computer management window, expand Local Users and Groups folder, and then expand Users folder to display all user accounts on this computer.<br /><br />Step 3. Right-click Administrator and select Set Password option.<br /><br />Among these tips, it's highly suggested you try tip 2 that changing Windows XP password with Windows password recovery software as it is can be applied to every lost Windows password circumstances. And it is simple and fast.
on Apr 22, 2011 | Computers & Internet
Tip
How do you reset a lost windows XP administrator password?
This tutorial will only work in windows xp.
On start up (before Windows loads),Immediately press F8 simultaneously.Click on "Safe Mode".When you are asked to log in, log in to "Administrator" (shouldn't have a password).Go to "Control Panel" by clicking on the START button.Go to "User Accounts".
Look for the account and either delete the password or change it.
step 2:
insert xp cd and boot ur system in bootable xp cd
then go to second repair option .After system restart 39 min remaining At the press shift f10 .At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel,change the password and run the repair setup.Now your administrator password changed
Follow the steps below to quickly find the administrator password on your computer!
1. Try leaving the password blank. More often than not, the Administrator password doesn't exist at all! Just press Enter without typing anything when asked for it.
2. Enter the password to your account. Often times, depending on how Windows XP was setup on your computer, the primary user account will also be the administrator user account.
3. Recover Windows XP administrator password using Windows Password Key. Windows Password key is a program reset any Windows password without reinstalling the OS.
4. Perform a clean installation of Windows XP. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch. If you're just curious about your administrator password, I wouldn't suggest this extreme solution.
However, if you're needing the administrator password to access diagnostic tools and this is your last effort to save your PC, performing a clean install will work. Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
More information and Tutorial to password from lost windows password website.
on Jul 07, 2010 | Computers & Internet
I need to reset my password on my Dell Studio 1535.I forgot what it was and cannot start up without
also
hope this helps you
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.:
Close the User Accounts window and restart Windows.:
hope this helps you:
Sep 26, 2011 | Intel D865GLCLK Motherboard
When my acer aspire 9300 laptop is turned on it says password i dont no what it is can u help
Well, I am providing you four tips which you can consider to recover Windows administrator password if your forgot or lost it:
TIP 1 - Use password reset disk
Windows-based system was designed to be able to create windows password reset disk without any other third party tools. So you can make use of a password reset disk to reset your Windows password in case you lose or forget your Windows password.
TIP 2 - Restore the operating system
Windows password recovery can be performed by restoring the operating system. Since restoration leads to data deletion, the solution can only work if you have a clean and updated backup of your hard drive data stored somewhere else.
TIP 3 - Use Windows Boot disk
The boot CD for Windows can be used to reset the administrator password. This disk enables you to repair Windows OS, thereby, setting your administrator password as blank.
TIP 4 - Use password recovery software
This is considered as the best windows password recovery solution, however, is to download a third party software. These tools enable you to reset Windows administrator password without posing any threat to your hard drive data. Among so many password recovery software, windows Password Recovery 6.0 is an easy-to-employ application which can be used to reset lost or forgotten password of any Windows system. Now execute the following steps to recover your lost windows password if you haven't prepared anything.
Step1: Login to a computer that can link to Internet. Download Windows Password Recovery from
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and install it on that PC.
Note that: there is an .ISO file. Burn the .ISO file to a CD/DVD or a USB flash drive
Step2: Get out the newly created CD/USB and insert it to the locked computer.
Step3: re-booted the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old passwords were removed.
Step4: logon PC without password and setting the new password
Sep 24, 2010 | Computers & Internet
I cant' sign it and I'm a member !
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's great!
http://www.resetwindowspassword.com
May 18, 2009 | Microsoft Windows Vista Home Premium...
Forgot my password
Lost passwords are never good. Not all hope is lost, so long as you aren’t using the master Administrator account. You didn’t specify which operating system you were using, but this tip is for XP only, as the main Administrator account is disabled in Vista by default.First thing you’re going to do is reboot your computer. When it comes on, press the F8 key (you may need to tap this a few times, just to make sure you’re hitting it at the appropriate time). You should be greeted with a prompt for booting into Windows, select Safe Mode. When the computer finishes booting, you should see an account labeled Administrator. Try to log into this account. If no administrator password was setup when you installed Windows, it may let you right in. Otherwise, you’ll need to remember that password that you set.
Once in this account, head into the Control Panel and access the Users area. You should be able to select the account you generally use, and reset the password. If you can’t get into the main Administrator .
Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.For example generally
Manufacturer BIOS Password
Toshiba Toshiba
Apr 18, 2009 | Computers & Internet
Nope, if you do not have the bios password, the only way to reset it is by accessing the motherboard, removing case and keyboard, and either removing Cmos coin shaped battery for one second, or bridgeing the Cmos reset jumper (that interrupts contact to battery, same as removing battery).
Oct 09, 2008 | HP Compaq nx6110 Notebook
HP laptop 9000 need help installing webcam
Feb 22, 2008 | HP Compaq nx6110 PC Laptop
HP Pavilion dv1000 Notebook Logo
223 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
