Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive
Toshiba Sattelite Won't Boot
Wont start & there is no way I can fix it... Goes to screen with 'Start windows normally' and other things; Tried every single one and still doesn't start up.
  • reisertracin Oct 20, 2008
    I have the same problem, computer comes on then shuts off, no matter what I do with f keys it does the same thing, please advise.
Re install windows;) ?
Posted on Dec 18, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
Toshiba Sattelite PRO L300 telling me checking file system C one of disks needs to be checked However it then says an error has occured and won't leave this screen !
Press F8 and choose command prompt.You may have to use a boot disc if you can't get c prompt.
Type cmd ENTER. From the Command Prompt type chkdsk /r/f ENTER. R and F are redundant for repair and fix, but does not hurt.
Oct 29, 2012 | Toshiba Satellite Pro L300 Notebook
Toshiba wont boot
From the description your hard drive is the issue, have it tested to see if it must be replaced.
Jul 08, 2012 | Toshiba Satellite L305-S5875 Notebook
Im having problems with my Toshiba Satellite L455DS5976 it wont start up. it will go to the normal toshiba screen when you turn it on but after that the screen goes blank and theres a white line what...
I had the same problem. Let it run that way for about 5-10 minutes, it should show a menu, choose START WINDOWS NORMALLY.
It will take some more time to boot, be patient. Once you start it, do the clean up, virus check and delete everything you don't it. That worked for me.
If this helps, please rate. Thank you
Jan 15, 2011 | Toshiba Satellite L455DS5976 Notebook
My laptop has been freezing for a while now, I've been getting a black screen with a blue bar across the bottom of the screen where the taskbar should be. Sometimes it boots up and makes me go into...
If you have Windows Installation disk, use to repair Windows.
First go inside BIOS(Setup) with Del or F2 and change under boot options for CD/DVD to boot up first before HDD.
Put the CD in, boot from it and select repair windows once it comes up
Jul 19, 2010 | Toshiba Computers & Internet
My toshiba sattelite wont start has blank screen plz help wont let me do anything at all
it could be memory chip boot failure...try switchin
it around...i dont know..but jst try it...
Dec 03, 2009 | Toshiba Satellite 5005-S504 Notebook
I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Dec 15, 2008 | Toshiba Sattelite A105-S2071 Notebook
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive Logo
143 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
