Question about Pantech Duo Smartphone
Using a ringtone for text alert
How can I set a ring tone to notify me when I receive a text?
  • juagar_19 Jan 14, 2009
    i cant set any ringtone on my pantech phone can anybody help pls.
  • karmenmary May 11, 2010
    ok so i did everything like it said to and the ringtones are showing up but they're not working. its telling me the ringtone file is corrupted or unavailable. can u tell me what i did wrong? and how can i fix it so they work
  • 3 Answers
Always think carefully about altering your phone's window registry for any reason. If you follow the instructions all should be fine. If you are a complete novice, I wouldn't recommend it, you could seriously mess up your phone. Use at your own discretion.
*WARNING I DO NOT know the extent at which this works ( "How many tones that can be added""How long the ringtones can be"FOLLOW THE INSTRUCTIONS!! I AM NOT/WILL NOT BE RESPONSIBLE FOR ANY DAMAGE CASUED TO YOUR PANTECH DUO BY PERFORMING THIS PROCESS!! Doing this involves tinkering with the phones defaults if you change something that you are not supposed to the phone may not work causing the phones warranty to be void (Solution:If your not sure what your doing DONT DO IT). Before you start make sure all ringtones you desire to be used as alerts for text messages, voicemail, etc. are in the "\My Documents\My Ringtones\" folder. This is very important as you will see. Also make sure all ringtones are short enough (15 seconds MAX) that they will be recognized as useable tones*
1. Download the Mobile Registry Editor (Don't worry it's Free) http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
2. Connect your Pantech Duo to your Desktop/Laptop and run the registry editor
3. Once your device and has been connected to the Editor open "HKEY_CURRENT_USER" (should be the second file folder down)
4. Open "Control Panel" (this should also be the second file folder down)
5. Click (and only click) "Sounds" (Should be the 15th file folder down *make sure its just "Sounds" and not "SoundCatergories"*)
6. Double Click "All Sounds"
7. In the pop up menu box scroll down to the end of the list of assorted factory tones
8. Put your cursor at the end of the last line and press enter to creat a new line to type in
9. Type in " \My Documents\My Ringtones\ " immediately by the exact name of the file you wish to enter ( EXAMPLE: \My Documents\My Ringtones\342.wow.mp3) MAKE SURE YOU ADD THE FILE TYPE (.wma,.mp3, etc.)
10. Click "OK" when you are finsihed adding your ringtones
11. On your Pantech Duo from the home menu Click Start>Settings>Sounds>Text Message then scroll through the tone options to reveal that tones you added are options and and can be play automatically!!
Reply and tell me if it worked, if it didn't, or if the directions are unclear P.S. have someone text you to double check if it works
Posted on Aug 30, 2008
I want to go onto settings to personalise ri gtones etc
Hi Elaine,
This will very depending on your phone manufacture and model. In general you will go to
1) settings
2) Device (this is only on some smart phones, if you don't see this skip this step)
3) Sounds and Notifications
4) Ring tones and sound
5) To change your ring tone choose Ringtone
6) to change message ringtone (ex, Text or email) choose Message
7) If you have a smart phone you can changes your notification sound by clicking on Notification Sounds. (a notification is when your lets you know you have received a missed call, text, email. it notifies you of something)
Jan 03, 2016 | Cell Phones
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
Jan 30, 2010 | Nokia 6101 Cellular Phone
On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
this will help you tons...
http://www.lg-vu.com/index.php?topic=4877.0
Nov 11, 2008 | LG Vu CU920 Cellular Phone
Setting ringtones as you text message alert tones
You CAN set a song as your text alert tone. Here are the steps:
1- Go to: Settings> Profiles>
2- Select your options (e.g. normal, vibrate and ring, etc....)
3- select Options> Customize (2)>
4- Highlight "Message Sound" and select Options> Customize (2),
5- Then browse to the folder your song or sound is in (e.g. audio) and select the file you want to use and save it.
I noticed that the songs have to be under 30 seconds to use as any type of alert tone for calls or texts.
Hopefully this helps.
Aug 10, 2008 | LG Shine KE970 Cellular Phone
I would like to change text message ring tone but can only find how to change ringtone and not for text messages
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
Jul 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Set a ringtone for a text message SYNC SGH-A707
"My Effect Tones" can only be MMF files. Ringtones can be WAV, MMF, MP3, etc... as long as the file is under 300kb I think. You need to convert your ring tones to MMF to use them as "Text Tones"
Jun 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Pantech Duo Smartphone Logo
259 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
