Question about Jenn-Air Ovens
Need help unlock oven after self cleaning jenn air jjw9527
I have clean the oven last night and the fan is on and it's still locked. Can you help?
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Posted on May 10, 2009
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
The self cleaning oven is not working. The fan in the back of the oven turns very slowly. the door locks briefly and then unlocks and everything shuts off.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Jenn-Air W30400P Stainless Steel Electric...
I have an older jenn air double oven and I locked it to clean and now I don't know how to unlock to open it again
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 24, 2010 | Jenn-Air Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Ovens Logo
210 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
