Question about Kodak EasyShare C613 Digital Camera
Kodak Easyshare C613
When I switch on the canera, I have a message on the screen:
Lens error 111,0,026 What does this mean, and can I fix this without having to take the camera to a shop
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
SOURCE: CAMERA ISSUES--KODAK easyshare C613
Easier Way:
Turn on the camera without the cord plugged in, and push the Menu button in back, scroll down to the SET ALBUM (STILL) which is probably in the OFF mode. When you hit OK it will probably tell you to connect to the computer. Then you plug in your cord.
You may have to put your Easy Share disk in at that time and load or reload the software but it should then allow you to download all your photos into into a Kodak folder. Then you can burn them to a DVD or select as many as you want and move to a regular folder on your computer.
Posted on Dec 31, 2007
  • 203 Answers
SOURCE: can i use my "kodak easyshare c613" as web cam?thx
the c613 will not stream anything through camera-mostly only some camcorder models will act as webcams also
Posted on May 29, 2008
SOURCE: Kodak EasyShare C613 not able to connect through USB
IT TELLS ME CANT LOCATE MY DRIVER FOR MY KODAK C613 CAMERA
Posted on Oct 10, 2008
SOURCE: Kodak Easyshare c613 lens error
i looked at this then snapped the lense back in place
Posted on Nov 15, 2008
  • 11967 Answers
SOURCE: kodak easyshare c182 lens error 111
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 13, 2010
My daughter's Kodak easyshare c613 gives lens error 415, 1, 1, 102 and the zoom in function doesn't work. Can we fix this?
In my experience when there is a 'lens error' there is internal damage perhaps from dropping the unit and it is fixable only by the Kodak.com website's authorized service center.
http://support.en.kodak.com/app/answers/detail/a_id/19879
Dec 18, 2010 | Kodak EasyShare C613 Digital Camera
When i switch on my kodak easy share c613 camera, it displays lens error:111,0,0,0 followed by lens error :221,0,0,0 and then goes off.please help.
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Dec 07, 2010 | Kodak EasyShare C613 Digital Camera
Hi, My Kodak EasyShare C613 intermittently starts up ok, but other times the lens extends and the viewfinder stays on the initial screen. (The Kodak EasyShare system 'share') After around 40 seconds...
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
Nov 04, 2010 | Kodak EasyShare C613 Digital Camera
Kodak Easyshare C613 - lens error code 115,0,0,219
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 09, 2009 | Kodak EasyShare C613 Digital Camera
Lens won't come out (Kodak EasyShare C613)
i have the exact same camera
you can hang it up and get ready to buy a new one because its not a do it yourself job and it would cost more to have it fixed than it would to buy another one just like it
May 01, 2009 | Kodak EasyShare C613 Digital Camera
Lens Error 126 01 000
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 25, 2008 | Kodak EasyShare C613 Digital Camera
Lens error messages
Looks like the only thing to do is send it in for service, which if it's out of warranty is not very cheap. Or you can sell it on ebay or craiglist and use the money to buy a comparable one.
Good luck,
Lee
Jun 15, 2008 | Kodak EasyShare C613 Digital Camera
you need to clean your lens with a tissue sort of cloth, DO NOT GET IT WET! that will ruin your camera.
Jun 10, 2008 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
49 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
