Question about Saeco Magic Comfort Plus Espresso Machine
Venting The word Ventalate is appearing on the display screen. Can someone please tell me how to do this?
  • 1 more comment
  • cboston758 Aug 23, 2008
    I forgot to mention the machine that requires venting is a Saeco Magic Comfort Plus machine. Thanks!
    Ok, when I did that the display message read, brew unit miss and then eventually went back to ventilate.
    Is that something I can do myself and if so were would I find the replacement part?
  • 515 Answers
Try to make a cup of water(tea).
Posted on Aug 23, 2008
  • Mirko Blas
    Mirko Blas Aug 23, 2008
    I think you have to replace the flow meter in your machine.
  • Mirko Blas
    Mirko Blas Aug 24, 2008
    If you take off the top then you will see one or two little white plastic with two tubes, that is the flow meter.
    The spare part number is: 286473300
    Contact Saeco USA to see where you can get this spare part.
    Saeco USA Inc.
    7905 Cochran Road Suite 100
    Glenwillow, OH 44139
    Tel. 440-528-2000
    Fax 440-542-9173
    E-mail: info@saeco-usa.com
    Visit the Web: www.saeco-usa.com
    Have a nice day
    /Mirran
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Ventalate screen
Try this open the hot water valve then push in the steam knob, if that works then contact your nearest distributor and tell them you want a new style steam valve, this valve is stainless steel and works a lot better than the plastic one in the machine.
Jul 14, 2009 | Gaggia Titanium Espresso Machine
Panasonic KX-T7668 Change name displayed on extension??
This facility of changing name is in admin program. when you call up some body their name will bw displayed on your screen. It's fine .tell us that what name other person get.
Jul 14, 2009 | Panasonic Lands Phones
Copier not coping due to teo messages on the display, 020 and C-6
Hello sir; your machine temperatur too high need to reset the procedur as follow;
1, press "stop/clear" key, "start" key", and left copy density key.
2, press "stop/clear" key again.
3, enter U163 press "start".
4, when screen display "CLE" then press "start" again to reset.
May 29, 2009 | Kyocera Office Equipment & Supplies
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
No DISPLAY ON THE SCREEN
If the external display works fine then the most common fault is the Inverter board for the LCD. By having the external display function properly, the video signal from the video graphics card is working.
The other fault could be, but generally isn't, the TAB welds on the LCD. Usually when these go a portion of the display will be lost first or discoloration e.g. red/white/or black stripe appears.
I generally don't include the CCFL (Cold Cathode Florescent Lamps) as a fault as the inverter is what supplies the voltage to the lamps.
May 26, 2008 | Compaq Armada E500 Notebook
Saeco Magic Comfort Plus Espresso Machine Logo
276 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
