Question about Refrigerators
Frigidaire electrolux model # FRT1865AW6
The freezer is working fine. The refridgerator appears to not be working at all. The temp in the refridgerator is almost 60 degrees F.
  • Franklin Ouchida
    Franklin Ouchida May 11, 2010
    I can help you if you didn't get the solution... let me know.
  • 725 Answers
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. it in the refer middle top . there is a knob you can turn it slowly with a screwdriver .until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 25, 2008
SOURCE:
Electrolux Frigidaire Model # FRT21BW8DW0 NOT WORKING, HELP!!
Hello Emily R - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. I would personally recommend contacting the manufacturer for a listing of authorized technicians who may assist you in repairing your unit and reinstalling the part that has been removed due to liability reasons.
Oct 08, 2012 | Frigidaire Gallery Series GLRT86TEW 30"...
FRT21BW8DW0
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Use this link for future/current reference
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 23, 2017 | Electrolux Freezers
Freezer works refridgerator dont but the two crisper drawers do
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and that the fan is running.
Sep 06, 2009 | Frigidaire Refrigerators
Refrigerator will not reach desired temp (not below 60)
check the thermostat to the refridgerator side could be bad
Aug 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Refridgerator not cooling but freezer works
check to see if freezer has ice on it if so it is going to be the automatic defrost system
May 02, 2009 | Refrigerators
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
