Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
The door lock for self cleaning is in the lock position with the door open. i tryed to cancel it but would not. an F3 message came up when i pushed clean. is there a way to reset the system.
Unplug the unit or flip the breaker switch (easier). After about 30 seconds, the latch will retract, allowing the door to close. Re-start the self-cleaning process.
Posted on Apr 21, 2009
Self cleaning range - door is locked, food inside, and self clean malfunction
Here are a couple of remedies that may work:
1. Disrupt the power to the stove for at least 5 minutes. If the clean cycle has been on to heat the oven at all, wait until you are certain it is completely cooled down. Patience is a virtue. There should be no lights on the panel. This resets the stove and stove errors the majority of times. I usually pull the plug at the rear of the stove. It gives me a chance to clean the floor while waiting. Re-power and determine if the if the clean cycle cancels. If not, go to 2.
2. Push the door in and press "Cancel". There is a push button switch (not visible when the door is closed) that is also a part of the self clean circuit. This switch may not be fully depressed. If it does not cancel, press the "Bake" button and press "Start". If it continues on the clean cycle, allow it to run for approx. 5 minutes and then enter "Cancel". If it does not cancel, retry the #1 waiting longer than 5 minutes and repeat #2 sequence.
3. The door can not be disassembled when it is locked closed. The lock mechanism is at the top of the door in the center and approx. 2" down.. The latch operates from left (open) to right (lock). It may be possible to get a slim jim type device to disengage the latch. A piece of scrap spring steel pallet banding may work for this You may have to depress the "Cancel" while doing this/. Hopefully, your range cooperates and you do not have to try 3.
Let us know if any of these work for you.
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
I have a kenmore range with an e1 f5 error code after trying to use self cleaning oven. it now says oven is locked
E-1 F-5 is a faulty door latch switch. Try to turn breaker off to stove for about 30 seconds then turn breaker on while someone is pushing against oven door to relieve pressure. If this does not work try selecting self-clean mode again and then cancel it. If none of these work you will need to replace the lock latch assembly. Hope this helps.
May 31, 2010 | Kitchen Ranges
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Using the self cleaning for the oven
look for the door/ light switch (the door would normally have this pushed in),and press and hold it in, tricking the unit into thinking the door is actually closed. press the clean button then, see what happens. it should try to close itself entirely and then press the cancel button, it should return to normal resting position
Mar 10, 2008 | Ovens
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
272 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
