Question about Cameras
My brother took the memory card out of my camera and said he only looked at pictures then gave me back my memory stick when i put it back in there were no pictures on my camera so we put the stick back in the computer and there are no pictures to be found anywhere from that file or from my camera atall.
I would try using a undelete program like this one and try and see if you can undelete them.
Hope this helps. :-)
P.S. If you have taken pictures on the card after this, some of them might have been overwritten.
Posted on Oct 22, 2008
I can see all my pictures that I took on my camera but when I put my memory stick in the computer and at Walmart photo lab they are on my memory stick..why?
Trying taking the memory card to a computer and looking through it for the photos. Take them off and put on pc. Then format memory card. Place memory card back in camera and take a picture. Then put memory card back in pc and take original photos and drop into folder that has new picture you took. It should work by noe if not then get a new memory card. Then try again.
Jul 05, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Gx 1s memory card not formatted
Get USB card reader and Requva or similar software to recover card. Look like card is going bad……
Dec 30, 2017 | Samsung GX-1S Digital Camera
How do you transfer internal memory pictures to memory card? I have a Samsung Digimax L60 camera and I forgot to put my memory card in my camera and took pictures without it in. How do i transfer the...
Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
Thanks
Dec 30, 2009 | Samsung Digimax L60 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Internal Memory is full??
If you dont put a memory card in your camera it is forced to record on and read from the internal memory (which is pretty small). If you do insert a memory card (is it a memory stick?) you can read the card but not the internal memory. Try it both with and without the memory stick.
Apr 29, 2009 | Cameras
Lost Pics
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card:
http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
May 14, 2008 | Sony Cybershot DSC-T200 Digital Camera
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Memory card problem
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Jun 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
